I’ve seen a few posts regarding “Agent infeasible” errors and they all seemed to have been fixed by aiming to take up less memory on the intended hailo device, normally by using smaller models, smaller input resolutions, or smaller batch sizes.
I’ve put a lot of time into trying to produce a useble .hef file over the past few weeks, and today I decided to try and produce a model that probably won’t be capable enough for my use case just to see if I can get something small over the line.
I’ve successfully parsed and optimised 2x models with the DFC tutorial feature in Jupyter, 1 is yolov8s with 640x640 input, and the other is yolov8s with 960x960 input.
When i try to compile the 640x640 optimized har:
[info] Building optimization options for network layers...
[info] Successfully built optimization options - 2s 720ms
[info] Successfully built optimization options - 4s 883ms
[error] Mapping Failed (allocation time: 4s)
No successful assignments: concat17 errors:
Agent infeasible
BackendAllocatorException Traceback (most recent call last)
Cell In[4], line 1
----> 1 hef = runner.compile()
2 file_name = f"{model_name}.hef"
3 with open(file_name, "wb") as f:
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:911, in ClientRunner.compile(self)
899 def compile(self):
900 """
901 DFC API for compiling current model to Hailo hardware.
902
909
910 """
--> 911 return self._compile()
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_common/states/states.py:16, in allowed_states.<locals>.wrap.<locals>.wrapped_func(self, *args, **kwargs)
13 raise InvalidStateException(
14 f"The execution of {func.__name__} is not available under the state: {self._state.value}",
15 )
---> 16 return func(self, *args, **kwargs)
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:1128, in ClientRunner._compile(self, fps, mapping_timeout, allocator_script_filename)
1122 self._logger.warning(
1123 f"Taking model script commands from {allocator_script_filename} and ignoring "
1124 f"previous allocation script commands",
1125 )
1126 self.load_model_script(allocator_script_filename)
-> 1128 serialized_hef = self._sdk_backend.compile(fps, self.model_script, mapping_timeout)
1130 self._auto_model_script = self._sdk_backend.get_auto_alls()
1131 self._state = States.COMPILED_SLIM_MODEL if orig_state in SLIM_STATES else States.COMPILED_MODEL
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1910, in SdkBackendCompilation.compile(self, fps, allocator_script, mapping_timeout)
1908 def compile(self, fps, allocator_script=None, mapping_timeout=None):
1909 self._model.fill_default_quantization_params(logger=self._logger)
-> 1910 hef, mapped_graph_file = self._compile(fps, allocator_script, mapping_timeout)
1911 # TODO: https://hailotech.atlassian.net/browse/SDK-31038
1912 if not SDKPaths().is_internal:
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1904, in SdkBackendCompilation._compile(self, fps, allocator_script, mapping_timeout)
1898 if not model_params and self.requires_quantized_weights:
1899 raise BackendRuntimeException(
1900 "Model requires quantized weights in order to run on HW, but none were given. "
1901 "Did you forget to quantize?",
1902 )
-> 1904 hef, mapped_graph_file, auto_alls = self.hef_full_build(fps, mapping_timeout, model_params, allocator_script)
1905 self._auto_alls = auto_alls
1906 return hef, mapped_graph_file
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1880, in SdkBackendCompilation.hef_full_build(self, fps, mapping_timeout, params, allocator_script)
1878 config_paths = ConfigPaths(self._hw_arch, self._model.name)
1879 config_paths.set_stage("inference")
-> 1880 auto_alls, self._hef_data, self._integrated_graph = allocator.create_mapping_and_full_build_hef(
1881 config_paths.get_path("network_graph"),
1882 config_paths.get_path("mapped_graph"),
1883 config_paths.get_path("compilation_output_proto"),
1884 params=params,
1885 allocator_script=allocator_script,
1886 compiler_statistics_path=config_paths.get_path("compiler_statistics"),
1887 nms_metadata=self._nms_metadata,
1888 har=self.har,
1889 alls_ignore_invalid_cmds=self._alls_ignore_invalid_cmds,
1890 )
1892 return self._hef_data, config_paths.get_path("mapped_graph"), auto_alls
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:764, in HailoToolsRunner.create_mapping_and_full_build_hef(self, network_graph_path, output_path, compilation_output_proto, agent, strategy, auto_mapping, params, expected_output_tensor, expected_pre_acts, network_inputs, network_outputs, allocator_script, allocator_script_mode, compiler_statistics_path, nms_metadata, har, alls_ignore_invalid_cmds)
759 if self.hn.net_params.clusters_placement != [[]]:
760 assert (
761 len(self.hn.net_params.clusters_placement) <= self._number_of_clusters
762 ), "Number of clusters in layer placements is larger than allowed number of clusters"
--> 764 self.call_builder(
765 network_graph_path,
766 output_path,
767 compilation_output_proto=compilation_output_proto,
768 agent=agent,
769 strategy=strategy,
770 exit_point=BuilderExitPoint.POST_CAT,
771 params=params,
772 expected_output_tensor=expected_output_tensor,
773 expected_pre_acts=expected_pre_acts,
774 network_inputs=network_inputs,
775 network_outputs=network_outputs,
776 allocator_script=allocator_script,
777 allocator_script_mode=allocator_script_mode,
778 compiler_statistics_path=compiler_statistics_path,
779 nms_metadata=nms_metadata,
780 har=har,
781 alls_ignore_invalid_cmds=alls_ignore_invalid_cmds,
782 )
784 return self._auto_alls, self._output_hef_data, self._output_integrated_pb_graph
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:696, in HailoToolsRunner.call_builder(self, network_graph_path, output_path, blind_deserialize, **kwargs)
694 sys.excepthook = _hailo_tools_exception_hook
695 try:
--> 696 self.run_builder(network_graph_path, output_path, **kwargs)
697 except BackendInternalException:
698 try:
File ~/projects/vision/venv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:570, in HailoToolsRunner.run_builder(self, network_graph_filename, output_filename, compilation_output_proto, agent, strategy, exit_point, params, expected_output_tensor, expected_pre_acts, network_inputs, network_outputs, allocator_script, allocator_script_mode, compiler_statistics_path, is_debug, nms_metadata, har, alls_ignore_invalid_cmds)
568 compiler_msg = e.hailo_tools_error
569 if compiler_msg:
--> 570 raise e.internal_exception("Compilation failed:", hailo_tools_error=compiler_msg) from None
571 else:
572 raise e.internal_exception("Compilation failed with unexpected crash") from None
BackendAllocatorException: Compilation failed: No successful assignments: concat17 errors:
Agent infeasible
When i try the 960x960 optimized har:
[info] Successfully built optimization options - 9s 276ms
[info] Successfully built optimization options - 15s 384ms
[error] Mapping Failed (allocation time: 15s)
Agent infeasible by resources sanity.: Memory units capacity exceeded (available: 128, required: 161).
Cell In[4], line 1
900 """
902
909
910 """
15 )
1125 )
1902 )
1884 params=params,
1888 har=self.har,
1890 )
760 assert (
766 output_path,
768 agent=agent,
771 params=params,
780 har=har,
782 )
695 try:
698 try:
571 else:
What can I do to overcome this? And how can I make the solution repeatable so I can use this device as intended?
As I said, I don’t think the model input sizes will allow detection of some of the small objects for my use case, so i’d ideally like to understand how to use the compiler for any potential input.
Thanks in advance for any help!
