Hello Guys,
as one of many I have encountered the same frustrating warning regarding optimization with the DFC
I’ve tried both the manual installation route and the docker container route, always facing the same issue.
I will only refer from this point on to the usage of the docker container, since it is the recommended way for using the DFC.
When I check in the ubuntu docker host (in WSL) the nvidia driver will be detected
NVIDIA-SMI 565.77.01 Driver Version: 566.36 CUDA Version: 12.7
But starting the docker container the driver won’t be found:
WARNING: The NVIDIA Driver was not detected. GPU functionality will not be available.
Use the NVIDIA Container Toolkit to start this container with GPU support; see
https://docs.nvidia.com/datacenter/cloud-native/ .
Also the nvidia-smi command is unknown to the docker container.
cuDNN 8.9 seems to be active inside the container:
(hailo_virtualenv) hailo@DESKTOP-Q07QB8F:/local/workspace$ dpkg -l | grep cudnn
ii cudnn-local-repo-ubuntu2204-8.9.0.131 1.0-1 amd64 cudnn-local repository configuration files
hi libcudnn8 8.9.6.50-1+cuda11.8 amd64 cuDNN runtime libraries
and CUDA 11.8 too:
(hailo_virtualenv) hailo@DESKTOP-Q07QB8F:/local/workspace$ dpkg -l | grep cuda
hi cuda-cccl-11-8 11.8.89-1 amd64 CUDA CCCL
hi cuda-compat-11-8 520.61.05-1 amd64 CUDA Compatibility Platform
hi cuda-cudart-11-8 11.8.89-1 amd64 CUDA Runtime native Libraries
hi cuda-cudart-dev-11-8 11.8.89-1 amd64 CUDA Runtime native dev links, headers
hi cuda-driver-dev-11-8 11.8.89-1 amd64 CUDA Driver native dev stub library
hi cuda-keyring 1.0-1 all GPG keyring for the CUDA repository
hi cuda-libraries-11-8 11.8.0-1 amd64 CUDA Libraries 11.8 meta-package
hi cuda-nvcc-11-8 11.8.89-1 amd64 CUDA nvcc
hi cuda-nvrtc-11-8 11.8.89-1 amd64 NVRTC native runtime libraries
hi cuda-nvtx-11-8 11.8.86-1 amd64 NVIDIA Tools Extension
hi cuda-toolkit-11-8-config-common 11.8.89-1 all Common config package for CUDA Toolkit 11.8.
hi cuda-toolkit-11-config-common 11.8.89-1 all Common config package for CUDA Toolkit 11.
hi cuda-toolkit-config-common 12.3.52-1 all Common config package for CUDA Toolkit.
hi libnccl2 2.15.5-1+cuda11.8 amd64 NVIDIA Collective Communication Library (NCCL) Runtime
Of course, I’ve installed nvidia-docker2 before I’ve started the container
distribution=$(. /etc/os-release;echo $ID$VERSION_ID) \
&& curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add - \
&& curl -s -L \
https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list \
| sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update
sudo apt-get install -y nvidia-docker2
sudo systemctl restart docker
Sorry for the formatting of the terminal content looks like crap.
