I am using DFC 3.26 and I get the message:
However there is a GPU and all the required drivers. Also when I call nvidia-smi, it shows that the GPU is being used by hailo_ai_sw_suite/hailo_venv/bin/python
The first time, I ran the DFC using ‘hailo tutorial’, it displays:
[Warning] CUDNN version should be 8.9 or higher, found 9.0.
Can it be the issue ?
