I tried to convert .pt model into .hef to be able to run on rpi5, but got this error (see below). I installed newest DFC, and lates model zoo, I was able to parse .onnx moder to .har with this command :
hailo parser onnx license_plate_detector.onnx --start-node-names images --end-node-names output0 --hw-arch hailo8l
and then when I am trying to hailo compiler license_plate_detector_optimized.har --hw-arch hailo8l I got this(for better understanding full output) :
(new_hailo_env) dima-ubuntu@Dima:~/hailo_model_zoo$ hailo compiler license_plate_detector_optimized.har --hw-arch hailo8l
[info] Current Time: 20:23:35, 09/11/24
[info] CPU: Architecture: x86_64, Model: AMD Ryzen 9 7950X3D 16-Core Processor, Number Of Cores: 32, Utilization: 8.8%
[info] Memory: Total: 63GB, Available: 17GB
[info] System info: OS: Linux, Kernel: 4.4.0-22621-Microsoft
[info] Hailo DFC Version: 3.28.0
[info] Running `hailo compiler license_plate_detector_optimized.har --hw-arch hailo8l`
[info] Compiling network
[error] Mapping Failed (allocation time: 8s)
No successful assignment for: format_conversion1, concat17, feature_splitter9, shortcut_softmax1, reduce_max_softmax1, ew_sub_softmax1, reduce_sum_softmax1, ew_mult_softmax1, conv64
[error] BackendAllocatorException: Compilation failed: No successful assignment for: format_conversion1, concat17, feature_splitter9, shortcut_softmax1, reduce_max_softmax1, ew_sub_softmax1, reduce_sum_softmax1, ew_mult_softmax1, conv64
