Fail to run analyze noise on custom YOLOv11
code
with open(“optimize_model.py”, “w”) as f:
f.write(“”"
import os
Define your model’s HAR file name
model_name = “yolov11s”
hailo_model_har_name = f"/content/drive/MyDrive/orangePI/Hailo/yolov11/{model_name}_hailo_model.har"
Ensure the HAR file exists
assert os.path.isfile(hailo_model_har_name), “Please provide a valid path for the HAR file”
Initialize the ClientRunner with the HAR file
Define the model script to add a normalization layer
Normalization for [0, 1] range
alls = """
nms_postprocess(“/content/drive/MyDrive/Hailo/yolov11/yolov11_nms_layer_config.json”, meta_arch=yolov8, engine=cpu)
Load the model script into the ClientRunner
runner.load_model_script(alls)
Define a calibration dataset
calib_dataset = “/content/drive/MyDrive/Hailo/yolov11/processed_calibration_data.npy”
Perform optimization with the calibration dataset
runner.analyze_noise(calib_dataset, batch_size=2, data_count=16)
Save the optimized model to a new Quantized HAR file
quantized_model_har_path = f"/content/drive/MyDrive/orangePI/Hailo/yolov11/{model_name}_quantized_model.har"
print(f"Quantized HAR file saved to: {quantized_model_har_path}")
error
ValueError: Exception encountered when calling layer ‘lat_model’ (type LATModel).
in user code:
    File "/content/my_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/lat_utils/lat_model.py", line 392, in call  *
        metric.update_state(native, numeric, partial_numeric=partial_numeric)
    File "/content/my_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/lat_utils/lat_model.py", line 22, in update_state  *
        self.noise_energy.assign_add(tf.reduce_mean((native - numeric) ** 2))
    ValueError: Dimensions must be equal, but are 128 and 132 for '{{node lat_model/sub_295}} = Sub[T=DT_FLOAT](lat_model/conv_feature_splitter6_2/act_op/Identity, lat_model/conv_feature_splitter6_2/output_op/mul)' with input shapes: [2,1,400,128], [2,1,400,132].
Call arguments received by layer 'lat_model' (type LATModel):
  • inputs=tf.Tensor(shape=(2, 640, 640, 3), dtype=float32)
Full Quant Analysis: 12%|█▎ | 1/8 [00:55<06:31, 55.86s/iterations]
