Hi, I’m trying to run advanced Layer Noise Analysis on a ViT-Base model. I receive the following error when trying to run it. I know this is a known bug, were you able to find a workaround for it?
It’s crucial that I run the advanced analysis as I want to see what layer introduces noise when all of the others are not quantized
[info] Current Time: 23:58:50, 03/09/25
[info] CPU: Architecture: x86_64, Model: AMD EPYC 9B14, Number Of Cores: 8, Utilization: 0.3%
[info] Memory: Total: 62GB, Available: 58GB
[info] System info: OS: Linux, Kernel: 6.8.0-1025-gcp
[info] HailoRT Version: 4.20.0
[info] Running `hailo analyze-noise --data-path /local/shared_with_docker/image_dataset_normalized_200images.npy --analyze-mode advanced /local/shared_with_docker/model_zoo_clip_vit_large_level0_docker2025_checker_cfg_enabled.har`
Full Quant Analysis: 0%| | 0/64 [00:00<?, ?iterations/s]
Full Quant Analysis: 2%|▏ | 1/64 [00:03<03:33, 3.39s/iterations]Traceback (most recent call last):
File "/local/workspace/hailo_virtualenv/bin/hailo", line 8, in <module>
sys.exit(main())
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/main.py", line 111, in main
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 64, in run
ret_val = self._run(argv)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 111, in _run
return args.func(args)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/hailo_lat_cli.py", line 60, in run
runner.analyze_noise(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2072, in analyze_noise
self._analyze_noise(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2094, in _analyze_noise
return self._sdk_backend.run_layer_analysis_tool(data, data_count, batch_size, analyze_mode, **kwargs)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1078, in run_layer_analysis_tool
analyzer.run()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py", line 54, in run
return super().run()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py", line 150, in run
self._run_int()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py", line 86, in _run_int
self.analyze_full_quant_net()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py", line 208, in analyze_full_quant_net
lat_model.predict_on_batch(inputs)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py", line 2603, in predict_on_batch
outputs = self.predict_function(iterator)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/util/traceback_utils.py", line 153, in error_handler
File "/tmp/__autograph_generated_filepzxgdn2x.py", line 15, in tf__predict_function
retval_ = ag__.converted_call(ag__.ld(step_function), (ag__.ld(self), ag__.ld(iterator)), None, fscope)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py", line 2155, in step_function
outputs = model.distribute_strategy.run(run_step, args=(data,))
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py", line 2143, in run_step
outputs = model.predict_step(data)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py", line 2111, in predict_step
return self(x, training=False)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/utils/traceback_utils.py", line 70, in error_handler
File "/tmp/__autograph_generated_file_7r4tlty.py", line 188, in tf__call
ag__.for_stmt(ag__.converted_call(ag__.ld(self)._model.flow.toposort, (), None, fscope), None, loop_body_5, get_state_9, set_state_9, (), {'iterate_names': 'lname'})
File "/tmp/__autograph_generated_file_7r4tlty.py", line 167, in loop_body_5
ag__.if_stmt(ag__.not_(continue__1), if_body_3, else_body_3, get_state_8, set_state_8, (), 0)
File "/tmp/__autograph_generated_file_7r4tlty.py", line 163, in if_body_3
ag__.for_stmt(ag__.converted_call(ag__.ld(enumerate), (ag__.converted_call(ag__.ld(zip), (ag__.ld(output_native), ag__.ld(output_numeric), ag__.ld(output_partial_numeric)), None, fscope),), None, fscope), None, loop_body_4, get_state_7, set_state_7, (), {'iterate_names': '(i, (native, numeric, partial_numeric))'})
File "/tmp/__autograph_generated_file_7r4tlty.py", line 162, in loop_body_4
ag__.for_stmt(ag__.ld(metrics), None, loop_body_3, get_state_6, set_state_6, (), {'iterate_names': 'metric'})
File "/tmp/__autograph_generated_file_7r4tlty.py", line 161, in loop_body_3
ag__.converted_call(ag__.ld(metric).update_state, (ag__.ld(native), ag__.ld(numeric)), dict(partial_numeric=ag__.ld(partial_numeric)), fscope)
File "/tmp/__autograph_generated_fileq1jh1_9w.py", line 10, in tf__update_state
ag__.converted_call(ag__.ld(self).noise_energy.assign_add, (ag__.converted_call(ag__.ld(tf).reduce_mean, ((ag__.ld(native) - ag__.ld(numeric)) ** 2,), None, fscope),), None, fscope)
ValueError: in user code:
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py", line 2169, in predict_function *
return step_function(self, iterator)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py", line 2155, in step_function **
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py", line 2143, in run_step **
ValueError: Exception encountered when calling layer 'lat_model' (type LATModel).
in user code:
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/lat_utils/lat_model.py", line 392, in call *
metric.update_state(native, numeric, partial_numeric=partial_numeric)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/lat_utils/lat_model.py", line 22, in update_state *
self.noise_energy.assign_add(tf.reduce_mean((native - numeric) ** 2))
ValueError: Dimensions must be equal, but are 768 and 780 for '{{node lat_model/sub_45}} = Sub[T=DT_FLOAT](lat_model/conv_feature_splitter1_2/act_op/Identity, lat_model/conv_feature_splitter1_2/output_op/mul)' with input shapes: [1,1,197,768], [1,1,197,780].
Call arguments received by layer 'lat_model' (type LATModel):
• inputs=tf.Tensor(shape=(1, 224, 224, 3), dtype=float32)
Full Quant Analysis: 2%|▏ | 1/64 [00:15<16:35, 15.81s/iterations]
