I never managed to get optimization=4 compression=0 working.
First it complained DALI was not installed on the docker, so I did
pip install nvidia-dali-cuda110
pip install nvidia-dali-tf-plugin-cuda110
(not sure why it didn’t come with the docker.
Now, see the “long novel” below with the error messages during adaround calibration phase I think. Totally cryptic for most of us I guess.
My yaml and json are the original for yolov11m as found in the docker, with just the size changed to 1024x1024 in a couple of proper places
My alls is as follows.
Can you pleas help with a set of yaml/json/alls that would actually allow me to get through the hef creation process, using max optimize and 0 compress?
Thanks.
alls:
change_output_activation(conv74, sigmoid)
change_output_activation(conv90, sigmoid)
change_output_activation(conv105, sigmoid)
nms_postprocess(“/local/workspace/Yolo/yolov11m_nms_config.json”, meta_arch=yolov8, engine=cpu)
model_optimization_config(calibration, batch_size=4)
post_quantization_optimization(finetune, policy=enabled, learning_rate=0.00001)
model_optimization_flavor(optimization_level=4, compression_level=0)
Hef compilation:
(hailo_virtualenv) hailo@a:/local/workspace/Yolo$ hailomz compile --ckpt best_1024x1024.onnx --calib-path valid_16mar2025_for_Hailo_training --yaml ./yolov11m.yaml
Start run for network yolov11m …
[info] Translation started on ONNX model yolov11m
[info] Restored ONNX model yolov11m (completion time: 00:00:00.20)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.69)
[info] In order to use HailoRT post-processing capabilities, these end node names should be used: /model.23/cv2.0/cv2.0.2/Conv /model.23/cv3.0/cv3.0.2/Conv /model.23/cv3.1/cv3.1.2/Conv /model.23/cv2.1/cv2.1.2/Conv /model.23/cv2.2/cv2.2.2/Conv /model.23/cv3.2/cv3.2.2/Conv.
[info] Start nodes mapped from original model: ‘images’: ‘yolov11m/input_layer1’.
[info] End nodes mapped from original model: ‘/model.23/cv2.0/cv2.0.2/Conv’, ‘/model.23/cv3.0/cv3.0.2/Conv’, ‘/model.23/cv3.1/cv3.1.2/Conv’, ‘/model.23/cv2.1/cv2.1.2/Conv’, ‘/model.23/cv2.2/cv2.2.2/Conv’, ‘/model.23/cv3.2/cv3.2.2/Conv’.
[info] Translation completed on ONNX model yolov11m (completion time: 00:00:01.28)
[info] Appending model script commands to yolov11m from string
[info] Saved HAR to: /local/workspace/Yolo/yolov11m.har
Preparing calibration data…
[info] Loading model script commands to yolov11m from /local/workspace/Yolo/yolov11m.alls
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.47)
Calibration: 100%|███████████████████████████████████████████████████████████████████████████████| 64/64 [00:26<00:00, 2.44entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:27.97)
[info] Model Optimization Algorithm Matmul Equalization is done (completion time is 00:00:00.02)
[info] activation fitting started for yolov11m/reduce_sum_softmax1/act_op
[info] No shifts available for layer yolov11m/conv48/conv_op, using max shift instead. delta=0.3565
[info] No shifts available for layer yolov11m/conv48/conv_op, using max shift instead. delta=0.1783
[warning] Adaround: Dataset didn’t have enough data for dataset_size of 1024 Quantizing using calibration size of 1023
[info] Starting Adaround
[info] The algorithm Adaround will use up to 188.79 GB of storage space
[info] Using dataset with 1023 entries for Adaround
[info] Using dataset with 64 entries for bias correction
Adaround: 1%|▎ | 1/125 [1:57:20<242:31:16, 7040.94s/blocks, Layers=[‘yolov11m/conv1_output_0’]]
File “/local/workspace/hailo_virtualenv/bin/hailomz”, line 33, in
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 250, in compile
runner = _ensure_optimized(runner, logger, args, network_info)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 91, in _ensure_optimized
optimize_model(
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 353, in optimize_model
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2128, in optimize
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1970, in _optimize
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1125, in full_quantization
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1319, in _full_acceleras_run
optimization_flow.run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 306, in wrapper
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 335, in run
step_func()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 250, in wrapped
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 111, in parent_wrapper
hailo_model_optimization.acceleras.utils.acceleras_exceptions.SubprocessTracebackFailure: Subprocess failed with traceback
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 73, in child_wrapper
func(self, *args, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 360, in step2
self.post_quantization_optimization()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 420, in post_quantization_optimization
self._adaround()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 683, in _adaround
algo.run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/block_by_block/block_by_block.py”, line 344, in run
retval = super().run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py”, line 54, in run
return super().run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py”, line 150, in run
self._run_int()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/ada_round/ada_round_v2.py”, line 140, in _run_int
self._comperative_run(pre_quant_cb=self.core_logic)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/block_by_block/block_by_block.py”, line 288, in _comperative_run
self.infer_block_with_cache(block_model, blocks, interlayer_results_quant, quant_cache_dir, dataset_size)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/block_by_block/block_by_block.py”, line 145, in infer_block_with_cache
self._infer_block(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/block_by_block/block_by_block.py”, line 222, in _infer_block
result = call_block(sample)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/util/traceback_utils.py”, line 153, in error_handler
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/eager/execute.py”, line 52, in quick_execute
tensors = pywrap_tfe.TFE_Py_Execute(ctx._handle, device_name, op_name,
tensorflow.python.framework.errors_impl.ResourceExhaustedError: Graph execution error:
Detected at node ‘yolov11m_submodel/conv1/act_op/SelectV2’ defined at (most recent call last):
run(args)
optimize_model(
step_func()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 94, in parent_wrapper
proc.start()
File “/usr/lib/python3.10/multiprocessing/process.py”, line 121, in start
self._popen = self._Popen(self)
File “/usr/lib/python3.10/multiprocessing/context.py”, line 224, in _Popen
return _default_context.get_context().Process._Popen(process_obj)
File “/usr/lib/python3.10/multiprocessing/context.py”, line 281, in _Popen
return Popen(process_obj)
File “/usr/lib/python3.10/multiprocessing/popen_fork.py”, line 19, in init
self._launch(process_obj)
File “/usr/lib/python3.10/multiprocessing/popen_fork.py”, line 71, in _launch
code = process_obj._bootstrap(parent_sentinel=child_r)
File “/usr/lib/python3.10/multiprocessing/process.py”, line 314, in _bootstrap
self.run()
File “/usr/lib/python3.10/multiprocessing/process.py”, line 108, in run
self._adaround()
algo.run()
self._run_int()
self._infer_block(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/block_by_block/block_by_block.py”, line 217, in call_block
result = block_model(inputs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/utils/traceback_utils.py”, line 65, in error_handler
return fn(*args, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/training.py”, line 558, in call
return super().call(*args, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/base_layer.py”, line 1145, in call
outputs = call_fn(inputs, *args, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/utils/traceback_utils.py”, line 96, in error_handler
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1203, in call
for lname in self.flow.toposort():
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1210, in call
output = self._call_layer(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1334, in _call_layer
outputs = acceleras_layer(inputs, training=training, encoding_tensors=encoding_tensors, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/base_hailo_layer.py”, line 152, in call
for op_name in self._layer_flow.toposort_ops():
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/base_hailo_layer.py”, line 163, in call
op_result = op(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/atomic_ops/base_atomic_op.py”, line 1141, in call
if fully_native:
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/atomic_ops/base_atomic_op.py”, line 1143, in call
elif self.bit_exact:
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/atomic_ops/base_atomic_op.py”, line 1146, in call
outputs = self._numeric_run(inputs, training=training, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/atomic_ops/base_atomic_op.py”, line 1222, in _numeric_run
outputs_num = self.call_hw_sim(inputs_num_lossy, training=training, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/atomic_ops/activation_op.py”, line 1460, in call_hw_sim
for i in range(num_pieces):
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/atomic_ops/activation_op.py”, line 1468, in call_hw_sim
slopes = tf.where(condition, current_slope, slopes)
Node: ‘yolov11m_submodel/conv1/act_op/SelectV2’
failed to allocate memory
[[{{node yolov11m_submodel/conv1/act_op/SelectV2}}]]
Hint: If you want to see a list of allocated tensors when OOM happens, add report_tensor_allocations_upon_oom to RunOptions for current allocation info. This isn’t available when running in Eager mode.
[Op:__inference_call_block_290260]
