Error compiling from custom yolo11 onnx
Totally cryptic message I guess while building the hef, in the final stages.
Any help?
Context:0/4 Iteration 4: Trying parallel mapping…
cluster_0 cluster_1 cluster_2 cluster_3 cluster_4 cluster_5 cluster_6 cluster_7 prepost
worker0 V V V V V V V V V
worker1 V V V V V V V V V
worker2 * * * * * * * * V
worker3 * * * * * * * * V
Context:1/4 Iteration 4: Trying parallel mapping…
worker0 X V V V V V X V V
worker2 V V V V V V V V V
worker3 V V V V V V V V V
Context:2/4 Iteration 16: Trying parallel splits…
worker0
worker1
Context:2/4 Iteration 20: Trying parallel splits…
worker0
worker1
Context:2/4 Iteration 24: Trying parallel splits…
worker0
worker1
Context:2/4 Iteration 28: Trying parallel splits…
worker0
worker1
Context:2/4 Iteration 32: Trying parallel splits…
worker0
worker1
Context:2/4 Iteration 36: Trying parallel splits…
worker0
worker1
Context:2/4 Iteration 96: Trying parallel splits…
worker0
worker1
worker2
worker3
Reverts on pre-mapping validation: 21n: 36: Negative size is: 3
05:19 on split failed: 0a, iteration: 34: Negative size is: 3
Reverts on cluster mapping: 11teration: 39: Negative size is: 3
Reverts on inter-cluster connectivity: 150: Negative size is: 3
Reverts on pre-mapping validation: 66n: 37: Negative size is: 3
Reverts on split failed: 4a, iteration: 38: Negative size is: 3
[info] context_0 (context_0):
Iterations: 4
Reverts on cluster mapping: 0
Reverts on split failed: 0
[info] context_1 (context_1):
Iterations: 4
[info] context_2 (context_2):
Iterations: 100
[info] context_3 (context_3):
Iterations: 0 [ Did not run due to an error ]
[info] context_4 (context_4):
[warning] Failed recording best-effort buffers: l4_portal_from_conv_feature_splitter1_1_dc_to_concat2 was not found in toposort recipe during buffers override record
[error] Mapping Failed (Timeout, allocation time: 1h 10m 9s)
Resolver didn’t find possible solution.
worker 0 failed on Splitter shutdown timeout reached (status: 31)
worker 1 failed on Splitter shutdown timeout reached (status: 31)
worker 2 failed on Splitter shutdown timeout reached (status: 31)
worker 3 failed on Splitter shutdown timeout reached (status: 31)
Hey @Thor,
This can be related to a lot of issues. Without more info about the ALLS file you’re using, the performance level, and the YAML configuration, these are just general options:
Summary of Solutions
Issue Solution
Model Too Large Reduce input size, use a smaller YOLO variant
Inter-Cluster Mapping Fails Limit max_parallel_workers=2
Concat Layer Issue Break Concat into smaller operations or use feature_splitter
Incorrect Hardware Target Use --hw-arch hailo8l during compilation
Mapping Timeout Set mapping_timeout=7200 and enable_auto_mapping=True
Hi @Omria,
Thanks. It is something related to the size of the model, as smaller models with same yaml and alls work, I’ll send you the alls and yaml later.
But now I have a more pressing question
Supposing I generate a rectangular onyx (w: 1536, h:864) using the following:
yolo export model=best.pt format=onnx opset=11 imgsz=(864,1536)
There are two places where input size is defined in the hailo yaml chain:
"image_dims”: in yolov11m_nms_config.json
input_shape: in yolo.yaml
To define a rectangular input shape to match the onnx, do I have to modify one or both?
Are the dimension w,h or h,w ?
Thanks
Hey @Thor ,
To properly define a rectangular input shape (864×1536) for your Hailo YAML chain that matches your ONNX model, you need to modify two key settings:
  1. In yolov11m_nms_config.json:
    • Update image_dims to (864, 1536)
    • This affects post-processing operations like NMS and decoding
  2. In yolo.yaml:
    • Set input_shape to (864, 1536)
    • This defines the network’s input tensor dimensions
Hailo Uses (H,W)
If you encounter issues after making these changes, try swapping the dimensions to (1536, 864) in both files.
Thank you.
However I did not see any change in the time hailo takes to process an image
Meaning,
a yolo model (square by default) converted to onnx without changing imgsz, then create a hef specifying square images 1536x1536
Vs
a yolo model (square by default) converted to onnx specifying imgsz 864x1536, then create a hef specifying images 864x1536
Hailo takes the same time to process
Why?
