Hi, I managed to compile YOLOv8m from ONNX to HEF. The command I used was
hailomz compile --ckpt yolov8m.onnx --calib my-tiny-dataset --yaml yolov8m.yaml --end-node-names YOLOV8M-FEATURE-MAPS-NODES
The tiny dataset I used for calibration had only 20 images.
Although an HEF model was generated, I saw some apparent red flags that I don’t quite stand, as shown below
Context:0/3 Iteration 4: Trying parallel mapping...
cluster_0 cluster_1 cluster_2 cluster_3 cluster_4 cluster_5 cluster_6 cluster_7 prepost
worker0 V X V V V V V V V
worker1 V V V V V V V V V
worker2 * * * * * * * * V
worker3 V V V V V V V V V
Context:1/3 Iteration 4: Trying parallel mapping...
worker0 V * V V V V V V V
worker1 * * * * * * * * V
worker3 * * * * * * * * V
Context:2/3 Iteration 4: Trying parallel mapping...
worker2 V V V V V V V V V
Context:3/3 Iteration 0: Trying parallel splits...
worker0
There are my questions:
- What is the document that discusses this map? I skimmed the DFC User Guide release 3.28.0, but did not see a map like above.
- What is this map trying to tell me? Judging by the red color, I guess there is something wrong with the model. I have not run the model on the Hailo-8 HW yet.
Thanks
