Error Compiling Hef File
Hello
After using the same compilation script for over a year now I am suddenly getting errors when compiling a Yolov8s to Hef.
This is the error reported
[error] Mapping Failed (allocation time: 8s)
No successful assignments: concat17 errors:
Agent infeasible by resources sanity.: Memory units capacity exceeded (available: 128, required: 150).
sigmoid1 errors:
Agent infeasible by resources sanity.: Memory units capacity exceeded (available: 128, required: 149).
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1
sigmoid1 failed on kernel validation: 16x4 is not supported in sigmoid1
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd0
sigmoid1_sd0 failed on kernel validation: 16x4 is not supported in sigmoid1_sd0
sigmoid1 errors:
Agent infeasible by resources sanity.: Memory units capacity exceeded (available: 128, required: 148).
sigmoid1 errors:
Agent infeasible
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd4
sigmoid1_sd4 failed on kernel validation: 16x4 is not supported in sigmoid1_sd4
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd8
sigmoid1_sd8 failed on kernel validation: 16x4 is not supported in sigmoid1_sd8
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd12
sigmoid1_sd12 failed on kernel validation: 16x4 is not supported in sigmoid1_sd12
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd16
sigmoid1_sd16 failed on kernel validation: 16x4 is not supported in sigmoid1_sd16
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd20
sigmoid1_sd20 failed on kernel validation: 16x4 is not supported in sigmoid1_sd20
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd24
sigmoid1_sd24 failed on kernel validation: 16x4 is not supported in sigmoid1_sd24
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd28
sigmoid1_sd28 failed on kernel validation: 16x4 is not supported in sigmoid1_sd28
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd32
sigmoid1_sd32 failed on kernel validation: 16x4 is not supported in sigmoid1_sd32
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd36
sigmoid1_sd36 failed on kernel validation: 16x4 is not supported in sigmoid1_sd36
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd40
sigmoid1_sd40 failed on kernel validation: 16x4 is not supported in sigmoid1_sd40
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd44
sigmoid1_sd44 failed on kernel validation: 16x4 is not supported in sigmoid1_sd44
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd48
sigmoid1_sd48 failed on kernel validation: 16x4 is not supported in sigmoid1_sd48
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd52
sigmoid1_sd52 failed on kernel validation: 16x4 is not supported in sigmoid1_sd52
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd56
sigmoid1_sd56 failed on kernel validation: 16x4 is not supported in sigmoid1_sd56
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd60
sigmoid1_sd60 failed on kernel validation: 16x4 is not supported in sigmoid1_sd60
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
Agent infeasible
DW resources calculation failed: more than 1 subclusters are needed for 16bit L2 biases and contexts at sigmoid1_sd64
sigmoid1_sd64 failed on kernel validation: 16x4 is not supported in sigmoid1_sd64
sigmoid1 errors:
sigmoid1 errors:
sigmoid1 errors:
My questions are:
  1. how to work around this to successfully convert the Hef
  2. What could of caused this to happen
    Many Thanks
Hi @rob.hulme,
Could you please share the compilation script and the model script (alls) that you are using?
