It shows an error saying that the input shape is not supported. In this case, how should I proceed?
— Loading from Hailo Archive: dfine_l_coco.har —
— Loading 8 images for calibration —
— Starting Quantization… —
[info] For NMS architecture yolov5 the default engine is auto. For other engine please use the ‘engine’ flag in the nms_postprocess model script command. If the NMS has been added during parsing, please parse the model again without confirming the addition of the NMS, and add the command manually with the desired engine.
[info] Using the default score threshold of 0.3 (range is [0-1], where 1 performs maximum suppression) and IoU threshold of 1.0 (range is [0-1], where 0 performs maximum suppression).
Changing the values is possible using the nms_postprocess model script command.
[info] The activation function of layer dfine_l_coco/conv21 was replaced by a Sigmoid
[info] The activation function of layer dfine_l_coco/conv45 was replaced by a Sigmoid
[info] The activation function of layer dfine_l_coco/conv53 was replaced by a Sigmoid
An unexpected error occurred: Unexpected input_shapes at feature multiplier layer dfine_l_coco/feature_multiplier21, input_shapes=[[-1, 80, 80, 512], [-1, 80, 80, 512]] (type=<class ‘list’>)
