Customized YOLOv9c compile issue for Hailo8
I am trying to compile a cutsomized yolov9c model.
I have followed and succeed to get a ‘har’ file whichi was optimized by running runner.optimize(calib_dataset).
The last thing to do is compiling the har file to deploy the network on Hailo8 chip but there is an issue of it.
I got a following message when I try to compile it.
/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:896, in ClientRunner.compile(self) 884 def compile(self): 885 “”" 886 DFC API for compiling current model to Hailo hardware. 887 (…) 894 895 “”" → 896 return self._compile() File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_common/states/states.py:16, in allowed_states..wrap..wrapped_func(self, *args, **kwargs) 12 if self._state not in states: 13 raise InvalidStateException( 14 f"The execution of {func.name} is not available under the state: {self._state.value}“, 15 ) —> 16 return func(self, *args, **kwargs) File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:1113, in ClientRunner._compile(self, fps, mapping_timeout, allocator_script_filename) 1107 self._logger.warning( 1108 f"Taking model script commands from {allocator_script_filename} and ignoring " 1109 f"previous allocation script commands”, 1110 ) 1111 self.load_model_script(allocator_script_filename) → 1113 serialized_hef = self._sdk_backend.compile(fps, self.model_script, mapping_timeout) 1115 self._auto_model_script = self._sdk_backend.get_auto_alls() 1116 self._state = States.COMPILED_SLIM_MODEL if orig_state in SLIM_STATES else States.COMPILED_MODEL File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1763, in SdkBackendCompilation.compile(self, fps, allocator_script, mapping_timeout) 1761 def compile(self, fps, allocator_script=None, mapping_timeout=None): 1762 self._model.fill_default_quantization_params(logger=self._logger) → 1763 hef, mapped_graph_file = self._compile(fps, allocator_script, mapping_timeout) 1764 # TODO: Jira 1765 if not SDKPaths().is_internal: File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1757, in SdkBackendCompilation._compile(self, fps, allocator_script, mapping_timeout) 1751 if not model_params and self.requires_quantized_weights: 1752 raise BackendRuntimeException( 1753 "Model requires quantized weights in order to run on HW, but none were given. " 1754 “Did you forget to quantize?”, 1755 ) → 1757 hef, mapped_graph_file, auto_alls = self.hef_full_build(fps, mapping_timeout, model_params, allocator_script) 1758 self._auto_alls = auto_alls 1759 return hef, mapped_graph_file File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1733, in SdkBackendCompilation.hef_full_build(self, fps, mapping_timeout, params, allocator_script) 1731 config_paths = ConfigPaths(self._hw_arch, self._model.name) 1732 config_paths.set_stage(“inference”) → 1733 auto_alls, self._hef_data, self._integrated_graph = allocator.create_mapping_and_full_build_hef( 1734 config_paths.get_path(“network_graph”), 1735 config_paths.get_path(“mapped_graph”), 1736 config_paths.get_path(“compilation_output_proto”), 1737 params=params, 1738 allocator_script=allocator_script, 1739 compiler_statistics_path=config_paths.get_path(“compiler_statistics”), 1740 nms_metadata=self._nms_metadata, 1741 har=self.har, 1742 alls_ignore_invalid_cmds=self._alls_ignore_invalid_cmds, 1743 ) 1745 return self._hef_data, config_paths.get_path(“mapped_graph”), auto_alls File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:764, in HailoToolsRunner.create_mapping_and_full_build_hef(self, network_graph_path, output_path, compilation_output_proto, agent, strategy, auto_mapping, params, expected_output_tensor, expected_pre_acts, network_inputs, network_outputs, allocator_script, allocator_script_mode, compiler_statistics_path, nms_metadata, har, alls_ignore_invalid_cmds) 759 if self.hn.net_params.clusters_placement != []: 760 assert ( 761 len(self.hn.net_params.clusters_placement) <= self._number_of_clusters 762 ), “Number of clusters in layer placements is larger than allowed number of clusters” → 764 self.call_builder( 765 network_graph_path, 766 output_path, 767 compilation_output_proto=compilation_output_proto, 768 agent=agent, 769 strategy=strategy, 770 exit_point=BuilderExitPoint.POST_CAT, 771 params=params, 772 expected_output_tensor=expected_output_tensor, 773 expected_pre_acts=expected_pre_acts, 774 network_inputs=network_inputs, 775 network_outputs=network_outputs, 776 allocator_script=allocator_script, 777 allocator_script_mode=allocator_script_mode, 778 compiler_statistics_path=compiler_statistics_path, 779 nms_metadata=nms_metadata, 780 har=har, 781 alls_ignore_invalid_cmds=alls_ignore_invalid_cmds, 782 ) 784 return self._auto_alls, self._output_hef_data, self._output_integrated_pb_graph File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:696, in HailoToolsRunner.call_builder(self, network_graph_path, output_path, blind_deserialize, **kwargs) 694 sys.excepthook = _hailo_tools_exception_hook 695 try: → 696 self.run_builder(network_graph_path, output_path, **kwargs) 697 except BackendInternalException: 698 try: File /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:570, in HailoToolsRunner.run_builder(self, network_graph_filename, output_filename, compilation_output_proto, agent, strategy, exit_point, params, expected_output_tensor, expected_pre_acts, network_inputs, network_outputs, allocator_script, allocator_script_mode, compiler_statistics_path, is_debug, nms_metadata, har, alls_ignore_invalid_cmds) 568 compiler_msg = e.hailo_tools_error 569 if compiler_msg: → 570 raise e.internal_exception(“Compilation failed:”, hailo_tools_error=compiler_msg) from None 571 else: 572 raise e.internal_exception(“Compilation failed with unexpected crash”) from None BackendAllocatorException: Compilation failed: No successful assignments: concat36 errors: Agent infeasible
I have checked the layer ‘concat36’ is what I set as a ‘end_node_name’ when parsing the network.
Could you share any solution for that?
I have attached a link to download my source code and ‘onnx’ file.
Please run the notebooks as follows.
  1. parsing_network.ipynb
  2. optimize_model.ipynb
  3. compile.ipynb
Many thanks.
Hey @godhj ,
Your concat36 issue is likely related to concatenation layer constraints. Here’s how to fix it:
1. Check Input Constraints
  • Concat operations only support two input layers per operation
  • Split large concatenations:
concat0 = concat([layer1, layer2], mid_concat)
concat1 = concat([mid_concat, layer3], final_concat)
2. Try Layer Defusing
  • Defuse layers before concatenation:
layerA, layerB = defuse(original_layer, 2)
concat0 = concat([layerA, layerB], final_concat)
3. Verify End Node Selection
  • Ensure end_node_name points to a valid output layer
  • Try setting a different output as the end node
4. Check Quantization
  • Make sure concat36 is properly quantized:
5. Use Profiler for Debugging
hailo profiler  your_model.har
[…<==>…] Elapsed: 00:00:06
locale::facet::_S_create_c_locale name not valid
[error] BackendAllocatorException: Compilation failed: locale::facet::_S_create_c_locale name not valid
I encountered this error when run compile(),
