I have this model script for yolov6n model:
alls = [
'norm_layer1 = normalization([0.0,0.0,0.0], [255.0,255.0,255.0])\n'
'resize_input1 = resize(resize_shapes=[480,640],engine=nn_core)\n'
'rgb1 = input_conversion(yuv_to_rgb)\n'
'yuy2_to_yuv1 = input_conversion(input_layer1, yuy2_to_hailo_yuv)\n'
When I create yuyv dataset in 480x640 resolution and trying to create har file, I get this error:
hailo_model_optimization.acceleras.utils.acceleras_exceptions.BadInputsShape: Data shape (480, 640, 2) for layer detector/input_layer1 doesn't match network's input shape (480, 640, 3)
(480, 640, 3) is RGB format, and I have conversion in script from yuyv (480, 640, 2) to RGB (480, 640, 3), so why does the code want RGB as an input?
I am able to force (480, 640, 2) in (480, 640, 3) by just adding zeros in free space, and then code works and compiles .hef model eventually, but the model doesn’t work, I wondering that this forces conversion might be the cause
