Regarding the issue of Hailo Optimization
I encountered problems when creating the calibration dataset.
This script for creating the calibration data set
import os
import cv2
input_dir = r"C:\Users\AYAKA\calib"  # 原始图像目录
output_file = r"C:\Users\AYAKA\calib\calib_set.npy"  # 输出文件
target_size = (640, 640)
# 获取所有图像文件路径并排序
image_files = sorted([f for f in os.listdir(input_dir) if f.lower().endswith(('.png', '.jpg', '.jpeg'))])
# 初始化图像列表
image_list = []
# 读取并处理每一张图片
for img_name in image_files:
    img_path = os.path.join(input_dir, img_name)
    image = cv2.imread(img_path)
    if image is None:
        print(f"Skipping {img_name}, unable to read.")
        continue
    # 调整图像大小
    image = cv2.resize(image, target_size, interpolation=cv2.INTER_AREA)
    image = np.array(image, dtype=np.uint8)
    image_list.append(image)
# 如果有有效的图像,保存它们到.npy文件
if len(image_list) > 0:
    calib_array = np.stack(image_list, axis=0)
    np.save(output_file, calib_array)
    print(f"Saved {output_file} with shape {calib_array.shape}")
else:
    print("No valid images found!")
I have converted the pt model of yolov8 to onnx.
Then this is the reason for the error.
pi@AYAKA:~$ hailo optimize yolov8n.har --hw-arch hailo8 --calib-set-path calib/ --output-har-path yolov8n_quantized_model.har
[warning] Cannot use graphviz, so no visualizations will be created
[info] For NMS architecture yolov8 the default engine is cpu. For other engine please use the 'engine' flag in the nms_postprocess model script command. If the NMS has been added during parsing, please parse the model again without confirming the addition of the NMS, and add the command manually with the desired engine.
[info] The layer yolov8n/conv41 was detected as reg_layer.
[info] The layer yolov8n/conv42 was detected as cls_layer.
[info] The layer yolov8n/conv52 was detected as reg_layer.
[info] The layer yolov8n/conv53 was detected as cls_layer.
[info] The layer yolov8n/conv62 was detected as reg_layer.
[info] The layer yolov8n/conv63 was detected as cls_layer.
[info] Using the default score threshold of 0.001 (range is [0-1], where 1 performs maximum suppression) and IoU threshold of 0.7 (range is [0-1], where 0 performs maximum suppression).
Changing the values is possible using the nms_postprocess model script command.
[info] The activation function of layer yolov8n/conv42 was replaced by a Sigmoid
[info] The activation function of layer yolov8n/conv53 was replaced by a Sigmoid
[info] The activation function of layer yolov8n/conv63 was replaced by a Sigmoid
[warning] Reducing optimization level to 0 (the accuracy won't be optimized and compression won't be used) because there's less data than the recommended amount (1024), and there's no available GPU
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:01.46)
[warning] Optimize Softmax Bias:        Dataset didn't have enough data for sample_size of 4    Quantizing using calibration size of 1
  File "/home/pi/.local/bin/hailo", line 8, in <module>
    sys.exit(main())
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 116, in main
    return a.run()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 64, in run
    ret_val = self._run(argv)
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 111, in _run
    return args.func(args)
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_sdk_client/tools/optimize_cli.py", line 120, in run
    self._runner.optimize(dataset, work_dir=args.work_dir)
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2128, in optimize
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1970, in _optimize
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1125, in full_quantization
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1319, in _full_acceleras_run
    optimization_flow.run()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py", line 306, in wrapper
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 335, in run
    step_func()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py", line 250, in wrapped
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py", line 124, in parent_wrapper
    func(self, *args, **kwargs)
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 353, in step1
    self.pre_quantization_optimization()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 400, in pre_quantization_optimization
    self._collect_stats()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 475, in _collect_stats
    stats_collector.run()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py", line 54, in run
    return super().run()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py", line 145, in run
    self._setup()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/algorithms/stats_collection/stats_collection.py", line 76, in _setup
    self.validate_shapes()
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/algorithms/stats_collection/stats_collection.py", line 86, in validate_shapes
    layer.validate_shape(input_data[key])
  File "/home/pi/.local/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_io.py", line 199, in validate_shape
    raise BadInputsShape(self.full_name, input_shape, data_shape)
hailo_model_optimization.acceleras.utils.acceleras_exceptions.BadInputsShape: Data shape (160, 640, 640, 3) for layer yolov8n/input_layer1 doesn't match network's input shape (640, 640, 3)
I have modified the dataset code several times, but still cannot input multiple batches. I hope you can help me figure out where the problem lies.
I do not think your issue comes from the dataset code. I created a file with your code and optimized the Yolov8n model from the ModelZoo successfully.
谢谢你的回复,我之后用了tfrecode数据集,成功训练出来了yolov8s模型
