Could not open any dmaHeap device
Hello everyone,
I’m trying to run the YOLOv5 segmentation (but it happens with all models), but getting a hard time to find out why DMA is not allocated properly. Maybe you can see any incompatible or mismatching options in my configuration:
rpicam-hello -t 0 /usr/share/rpi-camera-assets/hailo_yolov5_segmentation.json --framerate 10
[0:06:01.516314489] [2272]  INFO Camera camera_manager.cpp:327 libcamera v0.4.0+53-29156679
[0:06:01.523838797] [2277]  INFO RPI pisp.cpp:720 libpisp version v1.1.0 e7974a156008 27-01-2025 (21:50:51)
[0:06:01.546943270] [2277]  INFO RPI pisp.cpp:1179 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/imx477@1a to CFE device /dev/media1 and ISP device /dev/media2 using PiSP variant BCM2712_D0
Made X/EGL preview window
Mode selection for 2028:1520:12:P(10)
    SRGGB10_CSI2P,1332x990/120.048 - Score: 3456.22
    SRGGB12_CSI2P,2028x1080/50.0275 - Score: 1083.84
    SRGGB12_CSI2P,2028x1520/40.0096 - Score: 0
    SRGGB12_CSI2P,4056x3040/10 - Score: 887
Stream configuration adjusted
[0:06:01.750460045] [2272]  INFO Camera camera.cpp:1202 configuring streams: (0) 2028x1520-YUV420 (1) 2028x1520-BGGR_PISP_COMP1
[0:06:01.750507159] [2277]  INFO RPI pisp.cpp:1484 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/imx477@1a - Selected sensor format: 2028x1520-SBGGR12_1X12 - Selected CFE format: 2028x1520-PC1B
dmaHeap allocation failure for rpicam-apps0
ERROR: *** failed to allocate capture buffers for stream ***
grep -i cma /boot/config.txt
# It doesn't work either with : dtoverlay=vc4-kms-v3d,cma-256
dtoverlay=vc4-kms-v3d,cma-192
Here then it should report at least 192M
vcgencmd get_mem dma
dma=0M
vcgencmd get_mem gpu
gpu=8M
dmesg output from user cmd:
dmesg | grep -i dma
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.011567] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.011600] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.011633] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.035032] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.035279] iommu: DMA domain TLB invalidation policy: strict mode
[    0.559885] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[    0.627480] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    0.778443] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[    2.085927] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[    2.085929] hailo 0000:01:00.0: Probing: Using userspace allocated vdma buffers
dmesg output from root (I don’t know why it is different from user)
dmesg | grep -i cma
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000002000000, size 192 MiB
[    0.000000] OF: reserved mem: 0x0000000002000000..0x000000000dffffff (196608 KiB) map reusable linux,cma
[    0.000000] Memory: 16403584K/16769024K available (13504K kernel code, 2220K rwdata, 4320K rodata, 5120K init, 1216K bss, 168832K reserved, 196608K cma-reserved)
And I also tweaked the kernel command line parameters:
cat /boot/firmware/cmdline.txt
root=PARTUUID=5db7ea31-02 rootfstype=ext4 rootwait net.ifnames=0 logo.nologo console=tty1
modules-load=dwc2,g_ether cma=384M cma_debug=on
cat /etc/udev/rules.d/custom.rules
SUBSYSTEM=="dma_heap", GROUP="video", MODE="0660"
My RPI 5 has 16 GB, this output is from inside X Window:
free -h
               total        used        free      shared  buff/cache   available
Mem:            15Gi       1.8Gi        12Gi       320Mi       1.5Gi        14Gi
Swap:             0B          0B          0B
Any help would be appreciated
Hernan
Hey @user144,
The rpicam app is a Raspberry Pi application, For more specialized help with this Raspberry Pi camera app issue, the Raspberry Pi forums would be the best place.
I will try to do these first :
The error dmaHeap allocation failure for rpicam-apps0 is coming from the Raspberry Pi camera application. You might want to try:
dtoverlay=vc4-kms-v3d,cma-384
If that setting (cma=384M) isn’t being applied correctly, you’ll need to add it to /boot/firmware/cmdline.txt.
Make sure, the ‘OS user’, you’re playing with, is in the group of the DMA devices!! (Group ‘video’ in my case below):
ubuntu@ubuntu-2404-pi5b:~$ ls -altr /dev/dma_heap/
total 0
drwxr-xr-x  2 root root      80 Dec 31  1969 .
crw-rw----  1 root video 252, 0 Mar 20 08:57 system
crw-rw----  1 root video 252, 1 Mar 20 08:57 linux,cma
drwxr-xr-x 19 root root   14780 Mar 20 08:57 ..
ubuntu@ubuntu-2404-pi5b:~$ id
uid=1000(ubuntu) gid=1001(ubuntu) groups=1001(ubuntu),4(adm),24(cdrom),27(sudo),30(dip),44(video),46(plugdev),100(users),113(lpadmin),123(sambashare),1000(lxd)
type or paste code here
I hope, this helps;-)
– Marco
Thank you. The permissions were correct, but only root had access to the camera. For future reference, it was only after I tested the udev rules that my user has now the required permissions to open the rpicam.
This is the command
sudo udevadm test /sys/class/dma_heap/system
That should not have been needed?! Not sure, what was going on on your system.
You did not be any chance keep the output from that udevadm command?
Here is the output, hope it helps:
This program is for debugging only, it does not run any program
specified by a RUN key. It may show incorrect results, because
some values may be different, or not available at a simulation run.
Trying to open "/etc/systemd/hwdb/hwdb.bin"...
Trying to open "/etc/udev/hwdb.bin"...
Trying to open "/usr/lib/systemd/hwdb/hwdb.bin"...
Trying to open "/lib/systemd/hwdb/hwdb.bin"...
Trying to open "/lib/udev/hwdb.bin"...
=== trie on-disk ===
tool version:          252
file size:        12873996 bytes
header size             80 bytes
strings            2695252 bytes
nodes             10178664 bytes
Loading kernel module index.
Found cgroup2 on /sys/fs/cgroup/, full unified hierarchy
Found container virtualization none.
Using default interface naming scheme 'v252'.
Skipping overridden file '/usr/lib/systemd/network/99-default.link'.
Skipping overridden file '/usr/lib/systemd/network/73-usb-net-by-mac.link'.
Skipping empty file: /etc/systemd/network/99-default.link
Skipping empty file: /etc/systemd/network/73-usb-net-by-mac.link
Created link configuration context.
Reading rules file: /usr/lib/udev/rules.d/50-firmware.rules
Reading rules file: /usr/lib/udev/rules.d/50-udev-default.rules
Reading rules file: /usr/lib/udev/rules.d/55-dm.rules
Reading rules file: /usr/lib/udev/rules.d/60-autosuspend.rules
Reading rules file: /usr/lib/udev/rules.d/60-block.rules
Reading rules file: /usr/lib/udev/rules.d/60-cdrom_id.rules
Reading rules file: /usr/lib/udev/rules.d/60-drm.rules
Reading rules file: /usr/lib/udev/rules.d/60-evdev.rules
Reading rules file: /usr/lib/udev/rules.d/60-fido-id.rules
Reading rules file: /usr/lib/udev/rules.d/60-flashrom.rules
Reading rules file: /usr/lib/udev/rules.d/60-infiniband.rules
Reading rules file: /usr/lib/udev/rules.d/60-input-id.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-alsa.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-input.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-dm.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-tape.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-v4l.rules
Reading rules file: /usr/lib/udev/rules.d/60-sensor.rules
Reading rules file: /usr/lib/udev/rules.d/60-serial.rules
Reading rules file: /usr/lib/udev/rules.d/64-btrfs.rules
Reading rules file: /usr/lib/udev/rules.d/65-libwacom.rules
Reading rules file: /usr/lib/udev/rules.d/70-camera.rules
Reading rules file: /usr/lib/udev/rules.d/70-joystick.rules
Reading rules file: /usr/lib/udev/rules.d/70-memory.rules
Reading rules file: /usr/lib/udev/rules.d/70-mouse.rules
Reading rules file: /usr/lib/udev/rules.d/70-power-switch.rules
Reading rules file: /usr/lib/udev/rules.d/70-touchpad.rules
Reading rules file: /usr/lib/udev/rules.d/70-uaccess.rules
Reading rules file: /usr/lib/udev/rules.d/71-seat.rules
Reading rules file: /usr/lib/udev/rules.d/73-seat-late.rules
Reading rules file: /usr/lib/udev/rules.d/73-special-net-names.rules
Reading rules file: /usr/lib/udev/rules.d/75-net-description.rules
Reading rules file: /usr/lib/udev/rules.d/75-probe_mtd.rules
Reading rules file: /usr/lib/udev/rules.d/78-sound-card.rules
Reading rules file: /usr/lib/udev/rules.d/80-debian-compat.rules
Reading rules file: /usr/lib/udev/rules.d/80-drivers.rules
Reading rules file: /usr/lib/udev/rules.d/80-libinput-device-groups.rules
Reading rules file: /usr/lib/udev/rules.d/80-net-setup-link.rules
Reading rules file: /usr/lib/udev/rules.d/81-net-dhcp.rules
Reading rules file: /usr/lib/udev/rules.d/85-hwclock.rules
Reading rules file: /usr/lib/udev/rules.d/90-alsa-restore.rules
Reading rules file: /usr/lib/udev/rules.d/90-libinput-fuzz-override.rules
Reading rules file: /usr/lib/udev/rules.d/95-dm-notify.rules
Reading rules file: /usr/lib/udev/rules.d/96-e2scrub.rules
Reading rules file: /usr/lib/udev/rules.d/99-systemd.rules
system: Preserve permissions of /dev/dma_heap/system, uid=0, gid=0, mode=0600
system: Successfully created symlink '/dev/char/253:0' to '/dev/dma_heap/system'
system: sd-device: Created empty file '/run/udev/data/c253:0' for '/devices/virtual/dma_heap/system'
DEVPATH=/devices/virtual/dma_heap/system
DEVNAME=/dev/dma_heap/system
MAJOR=253
MINOR=0
ACTION=add
SUBSYSTEM=dma_heap
USEC_INITIALIZED=197295150
Unload kernel module index.
Unloaded link configuration context.
