Detetection.py and global shutter camera
i managed to install everything and tested the hailo-rpi5-examples, everythin works fine except using my Raspberry Pi global shutter camera. Is there no support for it yet?
I’m getting this error:
Error: gst-resource-error-quark: Failed to allocate required memory. (13), …/sys/v412/gst4l2src.c(976): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:source:Buffer pool activation failed
Shutting down…
I tried my logitech USB camera and it worked.
The global shutter camera works fine with differenct scripts - i assume you need to add the video resolution maybe? 1456 x 1088? Couldn’t find out how.
I was thinking about getting a CSI to USB adapter, would that work? Thanks
Hi @Darklord_Ice,
How are you using the Raspberry Pi camera with the examples?
You might want to try using --input rpi.
Thank you it helped to solve my problem (device module 3 -standard raspberry pi 5 and hailo 26 tops)
