Compilation fails for YOLO11s ONNX model on Hailo8
Hi Hailo Team
I successfully trained a YOLO11s model using Ultralytics YOLO. I was able to export it to ONNX and run the parse and optimize steps without errors.
However, when I run the compilation step:
hailomz compile yolov11s --hw-arch hailo8 --calib-path ../images --resize 640 640 --classes 1 --har yolov11s.har --performance
I get the following error:
[error] BackendAllocatorException: Compilation failed: map::at
ONNX model was exported with:
  • opset=13
  • imgsz=640
  • simplify=True
  • dynamic=False
I have ~220 calibration images. Parsing and optimization steps complete successfully.
Could you advise how to successfully compile this model for Hailo8?
Thanks in advance!
Hi @Yogeesh_Hegde
Welcome to the Hailo community. At DeGirum (a SW partner of Hailo), we developed a cloud compiler to help users convert YOLO checkpoints to hef: Early Access to DeGirum Cloud Compiler. Please see if you find it helpful for your use case.
Hi sashi, DeGirum should implement nv12 to rgb and other conversions to be added in the hef.
Hi @Ivica_Frankovic
Thanks for the suggestion. However, since such conversion can be done in preprocessor, we are unlikely to add such an option to our cloud compiler.
