Hi All,
I’m trying to compile a finetuned yolov11 model as per this guide.
I’m getting an error: Performance Flow requires automatic resource utilization
[info] ClientRunner initialized successfully.[info] Loading network parameters[info] Starting Hailo allocation and compilation flow[info] Adding an output layer after conv102[info] Adding an output layer after conv105[info] Adding an output layer after conv87[info] Adding an output layer after conv90[info] Adding an output layer after conv71[info] Adding an output layer after conv74[info] Building optimization options for network layers…[info] Successfully built optimization options - 1m 11s 720ms[error] Mapping Failed (allocation time: 1m 12s)Performance Flow requires automatic resource utilization
[error] Failed to produce compiled graph[error] Failed to compile the model: Compilation failed: Performance Flow requires automatic resource utilization[error] BackendAllocatorException: Compilation failed: Performance Flow requires automatic resource utilization
Following this discussion, I set performance_param(compiler_optimization_level=1) in the alls file. This doesn’t seem to have helped though.
Any ideas?
