Hi everyone,
Following up. No this is my turn to say “No GPU chosen and no suitable GPU found, falling back to CPU.“
Has anyone successfully run the HAILO AI Suite Docker on Ubuntu 22.04 with the 580-open driver?
Could the open-kernel NVIDIA drivers be incompatible with CUDA inside the container, even when --gpus all is specified?
Any suggestions on how to make HAILO detect the GPU would be hugely appreciated.
Thanks in advance!
I have a fresh Ubuntu 22.04 LTS installation on a laptop with an NVIDIA GeForce RTX 5060 GPU and 32 GB RAM.
Here’s what I’ve done so far:
Installed nvidia-driver-580-open (the only driver that correctly detects the GPU).
Installed the latest Docker CE.
Set up nvidia-docker2 following the official instructions (https://hailo.ai/developer-zone/documentation/hailo-sw-suite-2025-10-for-hailo-8-8l/?sp_referrer=suite/suite_install.html).
Installed and ran the HAILO AI Software Suite Docker.
When launching, I get this message:
Starting new container
Running Hailo AI SW Suite Docker image with the following command:
docker run
I have 633 images from the training dataset. Then I converted my trained yolov11l.pt to .onnx and ran
hailomz compile \
--ckpt /local/shared_with_docker/best.onnx \
--calib-path /local/shared_with_docker/calib_output2/calib \
--yaml hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov11l.yaml \
--classes 1 \
--hw-arch hailo8
Unfortunately, the compile process starts but immediately prints:
[info] First time Hailo Dataflow Compiler is being used. Checking system requirements… (this might take a few seconds)
[Warning] CUDA version should be 12.5 or higher, found 11.8 .
[Warning] CUDNN version should be 9 or higher, found ..
Component Requirement Found
OS Ubuntu Ubuntu Required
Release 20.04 22.04 Required
Package python3-tk V Required
Package graphviz V Required
Package libgraphviz-dev V Required
Package python3.10-dev V Required
RAM(GB) 16 32 Required
RAM(GB) 32 32 Recommended
CPU-Arch x86_64 x86_64 Required
CPU-flag avx V Required
GPU-Driver 560 580 Recommended
CUDA 12.5 11.8 Recommended
CUDNN 9 . Recommended
Var:CC unset unset Required
Var:CXX unset unset Required
Var:LD unset unset Required
Var:AS unset unset Required
Var:AR unset unset Required
Var:LN unset unset Required
Var:DUMP unset unset Required
Var:CPY unset unset Required
In file included from /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/ndarraytypes.h:1929,
from /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/ndarrayobject.h:12,
from /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/arrayobject.h:5,
from /home/hailo/.pyxbld/temp.linux-x86_64-cpython-310/local/workspace/hailo_model_zoo/hailo_model_zoo/core/postprocessing/cython_utils/cython_nms.c:1145:
/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/npy_1_7_deprecated_api.h:17:2: warning: #warning "Using deprecated NumPy API, disable it with " “#define NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION” [-Wcpp]
17 | #warning "Using deprecated NumPy API, disable it with "
Start run for network yolov11l …
[info] Translation started on ONNX model yolov11l
[info] Restored ONNX model yolov11l (completion time: 00:00:00.27)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.10)
[info] In order to use HailoRT post-processing capabilities, these end node names should be used: /model.23/cv2.0/cv2.0.2/Conv /model.23/cv3.0/cv3.0.2/Conv /model.23/cv2.1/cv2.1.2/Conv /model.23/cv3.1/cv3.1.2/Conv /model.23/cv2.2/cv2.2.2/Conv /model.23/cv3.2/cv3.2.2/Conv.
[info] Start nodes mapped from original model: ‘images’: ‘yolov11l/input_layer1’.
[info] End nodes mapped from original model: ‘/model.23/cv2.0/cv2.0.2/Conv’, ‘/model.23/cv3.0/cv3.0.2/Conv’, ‘/model.23/cv2.1/cv2.1.2/Conv’, ‘/model.23/cv3.1/cv3.1.2/Conv’, ‘/model.23/cv2.2/cv2.2.2/Conv’, ‘/model.23/cv3.2/cv3.2.2/Conv’.
[info] Translation completed on ONNX model yolov11l (completion time: 00:00:02.42)
[info] Appending model script commands to yolov11l from string
[info] Saved HAR to: /local/workspace/yolov11l.har
Preparing calibration data…
[info] Loading model script commands to yolov11l from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov11l.alls
[info] Loading model script commands to yolov11l from string
[warning] Reducing optimization level to 0 (the accuracy won’t be optimized and compression won’t be used) because there’s less data than the recommended amount (1024), and there’s no available GPU
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.85)
Calibration: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:54<00:00, 1.18entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:55.36)
[info] Model Optimization Algorithm Matmul Equalization is done (completion time is 00:00:00.07)
[info] No shifts available for layer yolov11l/conv42/conv_op, using max shift instead. delta=0.3988
[info] No shifts available for layer yolov11l/conv42/conv_op, using max shift instead. delta=0.1994
[info] No shifts available for layer yolov11l/conv43/conv_op, using max shift instead. delta=0.0822
[info] No shifts available for layer yolov11l/conv43/conv_op, using max shift instead. delta=0.0411
[info] No shifts available for layer yolov11l/conv53/conv_op, using max shift instead. delta=0.0415
[info] No shifts available for layer yolov11l/conv53/conv_op, using max shift instead. delta=0.0207
[info] No shifts available for layer yolov11l/conv58/conv_op, using max shift instead. delta=0.1869
[info] No shifts available for layer yolov11l/conv58/conv_op, using max shift instead. delta=0.0934
[info] No shifts available for layer yolov11l/conv59/conv_op, using max shift instead. delta=0.3181
[info] No shifts available for layer yolov11l/conv59/conv_op, using max shift instead. delta=0.1590
[info] No shifts available for layer yolov11l/conv65/conv_op, using max shift instead. delta=0.0579
[info] No shifts available for layer yolov11l/conv65/conv_op, using max shift instead. delta=0.0289
[info] No shifts available for layer yolov11l/conv66/conv_op, using max shift instead. delta=0.7598
[info] No shifts available for layer yolov11l/conv66/conv_op, using max shift instead. delta=0.3799
[info] No shifts available for layer yolov11l/conv67/conv_op, using max shift instead. delta=0.3872
[info] No shifts available for layer yolov11l/conv67/conv_op, using max shift instead. delta=0.1936
[info] activation fitting started for yolov11l/reduce_sum_softmax1/act_op
[info] No shifts available for layer yolov11l/conv74/conv_op, using max shift instead. delta=0.8335
[info] No shifts available for layer yolov11l/conv74/conv_op, using max shift instead. delta=0.4167
[info] No shifts available for layer yolov11l/conv76/conv_op, using max shift instead. delta=1.2689
[info] No shifts available for layer yolov11l/conv76/conv_op, using max shift instead. delta=0.6345
[info] activation fitting started for yolov11l/reduce_sum_softmax2/act_op
[info] No shifts available for layer yolov11l/conv80/conv_op, using max shift instead. delta=1.9550
[info] No shifts available for layer yolov11l/conv80/conv_op, using max shift instead. delta=0.9775
[info] No shifts available for layer yolov11l/conv138/conv_op, using max shift instead. delta=1.0096
[info] No shifts available for layer yolov11l/conv138/conv_op, using max shift instead. delta=0.5048
File “/local/workspace/hailo_virtualenv/bin/hailomz”, line 33, in
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 248, in compile
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 91, in _ensure_optimized
optimize_model(
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 353, in optimize_model
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2206, in optimize
result = self._optimize(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2025, in _optimize
checkpoint_info = self._sdk_backend.full_quantization(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1138, in full_quantization
new_checkpoint_info = self._full_acceleras_run(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1376, in _full_acceleras_run
new_checkpoint_info = self._optimization_flow_runner(optimization_flow, checkpoint_info)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 2029, in _optimization_flow_runner
optimization_flow.run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 239, in wrapper
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 357, in run
step_func()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 153, in parent_wrapper
func(self, *args, **kwargs)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 376, in step1
self.core_quantization()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 443, in core_quantization
self._create_hw_params()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 491, in _create_hw_params
algo.run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py”, line 55, in run
return super().run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py”, line 159, in run
self._run_int()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/create_hw_params/create_hw_params.py”, line 353, in _run_int
comp_to_retry = self._create_hw_params_component(matching_component_group)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/create_hw_params/create_hw_params.py”, line 211, in _create_hw_params_component
retry_negative_exp_list = self._hanlde_negative_exponent(layer, matching_component_group)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/create_hw_params/create_hw_params.py”, line 227, in _hanlde_negative_exponent
algo.run()
self._run_int()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/neg_exponent_fixer/neg_exp_fixer.py”, line 77, in _run_int
l_fix = self.fix_output(l_fix)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/neg_exponent_fixer/neg_exp_fixer.py”, line 123, in fix_output
self._log_negative_exponent_shift(l_fix)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/neg_exponent_fixer/neg_exp_fixer.py”, line 227, in _log_negative_exponent_shift
raise NegativeSlopeExponentNonFixable(
hailo_model_optimization.acceleras.utils.acceleras_exceptions.NegativeSlopeExponentNonFixable: Quantization failed in layer yolov11l/conv143 due to unsupported required slope. Desired shift is 9.0, but op has only 8 data bits. This error raises when the data or weight range are not balanced. Mostly happens when using random calibration-set/weights, the calibration-set is not normalized properly or batch-normalization was not used during training.
(hailo_virtualenv) hailo@sage-304375:/local/workspace$ hailomz compile --ckpt /local/shared_with_docker/best.onnx --calib-path /local/shared_with_docker/calib_output2/calib --yaml hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov11l.yaml --classes 1 --hw-arch hailo8
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.11)
[info] Translation completed on ONNX model yolov11l (completion time: 00:00:02.36)
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.89)
Calibration: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:55<00:00, 1.16entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:56.59)
run(args)
optimize_model(
step_func()
algo.run()
self._run_int()
algo.run()
self._run_int()
