Hello, I have a Raspberry Pi 5 with Hailo support, and I successfully installed the necessary libraries in my virtual environment in Visual Studio Code using the newly released Python API. I tried running the yolox.hef file I developed for the Raspberry Pi 5 with the code from the Hailo-Application-Code-Examples repository on GitHub, but I encountered an error. How can I resolve this issue?Thank you.
Code:
resized_img = cv2.resize(frame, (INPUT_RES_H, INPUT_RES_W), interpolation = cv2.INTER_AREA)
input_data = {input_vstream_info.name: np.expand_dims(np.asarray(resized_img), axis=0).astype(np.float32)}
# create dictionary that returns layer name from tensor shape (required for postprocessing)
layer_from_shape: dict = {infer_results[key].shape:key for key in infer_results.keys()}
Error Message:
Exception has occurred: AttributeError
‘list’ object has no attribute ‘shape’
File “/home/halil/hailo_platform_venv/son.py”, line 67, in
AttributeError: ‘list’ object has no attribute ‘shape’
