Hi, all:
I try to convert a phi-2 model to onnx according to Phi-2 tutorial | onnxruntime. The onnx file was successfully generated and tested.
When I tried to convert the model.onnx to HAR, the hailo parser failed to support those functions defined in onnexruntime as shown below. Was it a limitation or I did it in a wrong way? Thanks!
[Note] the virtual environment is the 2025/4 version.
[info] Current Time: 15:14:28, 04/29/25
[info] CPU: Architecture: x86_64, Model: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz, Number Of Cores: 12, Utilization: 1.1%
[info] Memory: Total: 31GB, Available: 25GB
[info] System info: OS: Linux, Kernel: 6.8.0-57-generic
[info] Hailo DFC Version: 3.31.0
[info] HailoRT Version: 4.21.0
[info] PCIe: 0000:03:00.0: Number Of Lanes: 4, Speed: 8.0 GT/s PCIe
[info] PCIe: 0000:04:00.0: Number Of Lanes: 4, Speed: 8.0 GT/s PCIe
[info] Running `hailo parser onnx --har-path ./har --hw-arch hailo8l ./example-models/phi2-int4-cpu/model.onnx`
[info] Translation started on ONNX model model
[warning] Large model detected. The graph may contain either a large number of operators, or weight variables with a very large capacity.
[warning] Translation time may be a bit long, and some features may be disabled (e.g. model augmentation, retry simplified model, onnx runtime hailo model extraction, etc.).
File "/local/workspace/hailo_virtualenv/bin/hailo", line 8, in <module>
sys.exit(main())
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/main.py", line 111, in main
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 64, in run
return self._run(argv)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 104, in _run
return args.func(args)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 213, in run
self._parse(net_name, args, tensor_shapes)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 297, in _parse
self.runner.translate_onnx_model(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1187, in translate_onnx_model
parser.translate_onnx_model(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 194, in translate_onnx_model
onnx.checker.check_model(model)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/onnx/checker.py", line 163, in check_model
C.check_model_path(
onnx.onnx_cpp2py_export.checker.ValidationError: No Op registered for LayerNormalization with domain_version of 14
==> Context: Bad node spec for node. Name: /model/layers.0/input_layernorm/LayerNorm OpType: LayerNormalization
