I am trying to compile an HEF model.
I am just running these two lines
runner = ClientRunner(har=har_file, hw_arch=hw_arch)
hef_data = runner.compile()
It is crashing during compile, and giving me the error
[error] TypeError: expected str, bytes or os.PathLike object, not NoneType
With debugging, I can see that the problem happens here in hailo’s source code for hailo_tools_runner.py
def run_hailo_tools(tool_args, exe_name, client=None, server=None, builder_pb_input=None):
hailo_tools_path = SDKPaths().join_hailo_tools_path("build/" + exe_name)
return run_tool_from_binary(
hailo_tools_path,
tool_args,
client=client,
server=server,
builder_pb_input=builder_pb_input,
The problem is that the line hailo_tools_path = SDKPaths().join_hailo_tools_path("build/" + exe_name) is evaluating to None.
So why is this?
Well, let’s dig a bit deeper, and have a look at the SDKPaths class.
I has this method
It calls this method
def join_hailo_tools_path(self, path):
if self.is_internal:
hailo_sdk_internals = pkgutil.get_loader("hailo_sdk_internals")
package_dir = os.path.dirname(os.path.dirname(os.path.dirname(hailo_sdk_internals.get_filename())))
return os.path.join(package_dir, "sdk_server", "hailo_tools", path)
if self.is_release:
hailo_sdk_common = pkgutil.get_loader("hailo_sdk_common")
return os.path.join(os.path.dirname(os.path.dirname(hailo_sdk_common.get_filename())), "hailo_tools", path)
It basically it checks if self.is_internal and checks if self.is_release. In my case, both are False, so it returns None, and breaks the code!!!
(@hailo error handling would be nice!)
Ok so why is it returning None? I would expect .is_release to be True.
Well, as you see here, it decides whether it is a release or internal in this code
class SDKPaths(with_metaclass(Singleton, object)):
HAILO_TEMP_DIR_PREFIX = "hailo"
DEFAULT_BUILD_DIR = "build"
def __init__(self):
self._build_dir = type(self).DEFAULT_BUILD_DIR
self._custom_build_dir = None
self._has_graphviz = True
self._is_release = "site-packages" in os.path.dirname(os.path.dirname(hailo_sdk_common.get_filename()))
self._is_internal = pkgutil.get_loader("hailo_sdk_internals") is not None
It basically says, if the package was installed in the folder ‘site-packages’ then it must be a release.
However, Ubuntu does not install it in site-packages unless you are installing it inside a virtual env. But the docs to not say you MUST install in a venv. they only recommend it. Since i am isolating my environment by putting everything in a docekr container, I decided not to use venv. Whoops! that breaks everything!
@hailo, please fix the code so that this is possible, or at the very least, gives some sensible error message.
