TypeError: expected str, bytes or os.PathLike object, not NoneType - ONNX to HEF
I’m trying to compile a YOLOv8m model to a .hef file using Hailo-8L, starting from an ONNX model.
Environment Setup:
  • Main working directory: /home/hailo/shared/
  • Command used:
bash
CopyEdit
hailomz compile yolov8m \
  --har /home/hailo/shared/yolov8m.har \
  --calib-path /home/hailo/shared/datasets/images/train \
  --hw-arch hailo8l
YAML File:
/home/hailo/shared/hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov8m.yaml
yaml
CopyEdit
base:
  - base/yolov8.yaml
postprocessing:
  device_pre_post_layers:
    nms: true
  hpp: true
network:
  network_name: yolov8m
paths:
  network_path:
    - /home/hailo/shared/yolov8m.har
  alls_script: cfg/alls/generic/yolov8m.alls
  hef_name: yolov8m.hef
  output_dir: compiled_model_yolov8m
info:
  task: object detection
  input_shape: 640x640x3
  output_shape: 80x5x100
  operations: 78.93G
  parameters: 25.9M
  framework: pytorch
  training_data: coco train2017
  validation_data: coco val2017
  eval_metric: mAP
  full_precision_result: 49.9
  source: https://github.com/ultralytics/ultralytics
  license_url: https://github.com/ultralytics/ultralytics/blob/main/LICENSE
  license_name: AGPL-3.0
Model Script (.alls):
/home/hailo/shared/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8m.alls
python
CopyEdit
model_optimization_config(calibration, batch_size=2)
change_output_activation(conv58, sigmoid)
change_output_activation(conv71, sigmoid)
change_output_activation(conv83, sigmoid)
post_quantization_optimization(finetune, policy=enabled, learning_rate=0.000025)
nms_postprocess("/home/hailo/shared/hailo_model_zoo/hailo_model_zoo/cfg/postprocess_config/yolov8m_nms_config.json", meta_arch=yolov8, engine=cpu)
resources_param(max_apu_utilization=0.9, max_compute_16bit_utilization=0.9, max_compute_utilization=0.9, max_control_utilization=0.9, max_input_aligner_utilization=0.9, max_memory_utilization=0.85, max_utilization=0.0)
Postprocess Config (NMS):
json
CopyEdit
  "nms_scores_th": 0.2,
  "nms_iou_th": 0.7,
  "image_dims": [640, 640],
  "classes": 80,
  "regression_length": 16,
  "background_removal": false,
  "bbox_decoders": [
      "name": "bbox_decoder57",
      "stride": 8,
      "reg_layer": "conv57",
      "cls_layer": "conv58"
      "name": "bbox_decoder70",
      "stride": 16,
      "reg_layer": "conv70",
      "cls_layer": "conv71"
      "name": "bbox_decoder82",
      "stride": 32,
      "reg_layer": "conv82",
      "cls_layer": "conv83"
Output & Error:
text
CopyEdit
[info] Model Optimization Algorithm Quantization-Aware Fine-Tuning is done (completion time is 00:05:16.93)
[info] Saved HAR to: /home/hailo/shared/hailo_model_zoo/yolov8m.har
[info] Loading model script commands to yolov8m from /home/hailo/shared/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8m.alls
[error] TypeError: expected str, bytes or os.PathLike object, not NoneType
What I Tried:
  • Verified .har, .alls, and .json paths are correct.
  • Corrected post_quantization_optimization to use calibration instead of invalid finetune.
  • Ensured normalization values and NMS config are set properly.
Request:
Can someone confirm what typically causes the TypeError: expected str, bytes or os.PathLike object, not NoneType at the graph compilation step in this context? Is there a missing required path, output name, or value expected by the compiler?
Thanks in advance for your support.
Hey @Patryk_Basiaga,
The problem is in your CLI command. You’re mixing --har with --calib-path, which confuses the compiler. The --calib-path flag is only for when you’re compiling from ONNX files using --ckpt. When you pass both flags together, the compiler tries to load a checkpoint file that doesn’t exist, giving you that “NoneType” error.
Here’s the fix:
Since you’re using a HAR file, just drop the --calib-path argument:
  --hw-arch hailo8l \
  --hef-name yolov8m.hef \
  --output-dir compiled_model_yolov8m
That should solve your TypeError immediately.
If for some reason you actually wanted to compile from ONNX with calibration instead, you’d use:
  --ckpt /home/hailo/shared/yolov8m.onnx \
  --yaml /home/hailo/shared/hailo_model_zoo/cfg/networks/yolov8m.yaml \
  --hw-arch hailo8l
Your YAML and ALLS files are actually set up correctly - it’s just the CLI argument mismatch that’s breaking things.
Let me know if this fixes it for you!
Same here, this error
And the error goes on …
If anyone else has this issue, and on colab environment, problem is a poor path checking function. I solved it using the below monkey patch. It is assumed that we are in virtual env, or if the dfc is in site-packages.
!sed -i 's/"site-packages"/"site-packages" or "dist-packages"/'  /usr/local/lib/python3.11/dist-packages/hailo_sdk_common/paths_manager/paths.py
