Hi Folks,
I am trying to run the hailo model zoo project but I need the data flow compiler first as it stated here:
Where can we find it?
David
Hi Folks,
David
Hi @dudibs,
All our Packages are available in the Developer Zone: https://hailo.ai/developer-zone/software-downloads/
Regards,
Omri
@dudibs Please note that the Data Flow Compiler (DFC) is not yet available to Community users. We are actively working on its release and ensuring it is well-documented for easy use.
Stay tuned for updates.
I apologize for the inconvenience and appreciate your patience.
ok thanks.
Can I install the model zoo project and use it without the compiler?
You can’t install it w/o the DFC. However you can download our pre-compiled networks from the model zoo GitHub.
If you have a specific network you want to use start with the pre-compiled version. We will open DFC soon.
Thanks you for your patience and understanding.
Hi Gilad,
Thanks for the response.
I am managing to run the stuff from hailo application code examples. Work is smooth. However, I wish to use the compiled segformer which exists in the model zoo. available here:
It is not in the TAPPAS but I wish to interact with it. To send an image to the model and get the result…get the sense of accuracy and inference time.
How can I interact with this compiled model (segformer_b0_bn)l. Is there any instructions on how to build the application around this model so I can infer from it?
In the model-zoo there’s also a link from each model the repo it originated from, this is a good starting point.
Alternatively, you can implement a pipeline for the SegFormer based on the TAPPAS GStreamer plugins. There are general instrcutions on this link.
This would include writing/translating the post-processing function for the SegFormer either from the model-zoo or from the original git.
Please note that if you are using H8L (RPi AI kit) you’ll need to download the H8L version available here:
To check the inference time on you system you can use the hailortcli tool.
For example (Running on my laptop NOT RPi!!)
hailortcli run '/home/giladn/Downloads/segformer_b0_bn.hef'
Running streaming inference (/home/giladn/Downloads/segformer_b0_bn.hef):
Transform data: true
Type: auto
Quantized: true
[HailoRT] [warning] HEF was compiled for Hailo8L device, while the device itself is Hailo8. This will result in lower performance.
Network segformer_b0_bn/segformer_b0_bn: 100% | 38 | FPS: 7.59 | ETA: 00:00:00
> Inference result:
Network group: segformer_b0_bn
Frames count: 38
FPS: 7.59
Send Rate: 95.51 Mbit/s
Recv Rate: 31.84 Mbit/s
You can run with a different batch size to gain more performance:
hailortcli run '/home/giladn/Downloads/segformer_b0_bn.hef' --batch-size 3
Type: auto
Quantized: true
Network segformer_b0_bn/segformer_b0_bn: 100% | 54 | FPS: 10.78 | ETA: 00:00:00
> Inference result:
Frames count: 54
FPS: 10.79
Send Rate: 135.72 Mbit/s
Recv Rate: 45.24 Mbit/s
For post processing you can checkout the model zoo post process hailo_model_zoo/core/postprocessing/segmentation_postprocessing.py
thanks. I will do so.
How do I know if i have the regular H8 unit. or the H8L.
running lspci provides this info about the unit itself:
57:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
i think its not the L version. right?
Use this command:
thanks. It’s a regular 8.
I will try to add the post-process aspects of the compiled segformer to the TAPPAS…is it doable task by someone unfamiliar with hailo software such as myself?
$ hailortcli fw-control identify
Executing on device: 0000:57:00.0
Identifying board
Control Protocol Version: 2
Firmware Version: 4.17.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
Serial Number: HLLWMB0214600587
Part Number: HM218B1C2LA
Product Name: HAILO-8 AI ACCELERATOR M.2 B+M KEY MODULE
Why not? Give yourself aome credit👌
@dudibs Take the semantic segmentation post process in the TAPPAS as a starting point. tappas/core/hailo/libs/postprocesses/semantic_segmentation/semantic_segmentation.cpp
You can use our semantic segmentation app from an older TAPPAS version for pipeline example:
https://github.com/hailo-ai/tappas/blob/v3.26.2/apps/h8/gstreamer/general/segmentation/semantic_segmentation.sh
You will need to change the output layer in the post process function. (add the segformer_b0_bn prefix)
TIP: hailortcli parse-hef segformer_b0_bn.hef
To recompile TAPPAS postprocesses see instructions in tappas/docs/write_your_own_application/write-your-own-postprocess.rst at 4341aa360b7f8b9eac9b2d3b26f79fca562b34e4 · hailo-ai/tappas · GitHub
I’d be happy to get updates on your progress!
Thanks for that info Gilad. I have tried to follow your instructions but I am stuck.
Thus, My plan now is to:
Thanks
David
I am trying to run the tappas first, to get the feeling opf how it works. for instance operate the current that works there.
