Hello hailo community,\
I have a question reagarding to ONNX to hef conversion. I have a custom dataset which consists of single label (car).
When I try to convert it to the hef file the total distill loss is not decreasing. I am suspecting that this why I cant
get good accuracy when I run my model in runtime in hailo8. Detection performance is pretty good when I infer directly from torch.
Can you help me about it ? How can I solve this issue ?
This how I export my trained yolov8s model:
$: yolo export model=best.pt format=onnx opset=11 imgsz=640
I also use docker enviroment for hef conversion. These are versions of each tools:
$: hailo --version
[info] Current Time: 12:16:11, 12/27/24
[info] CPU: Architecture: x86_64, Model: Intel(R) Xeon(R) W-2195 CPU @ 2.30GHz, Number Of Cores: 36, Utilization: 0.8%
[info] Memory: Total: 125GB, Available: 52GB
[info] System info: OS: Linux, Kernel: 5.19.0-46-generic
[info] HailoRT Version: 4.19.0
[info] Running `hailo --version`
HailoRT v4.19.0
Hailo Dataflow Compiler v3.29.0
The following one is the model script that I use:
quantization_param([conv42, conv53, conv63], force_range_out=[0.0, 1.0])
nms_postprocess("../../postprocess_config/yolov8s_nms_config.json", meta_arch=yolov8, engine=cpu)
I use this command to compile:
hailomz compile --ckpt /local/shared_with_docker/best.onnx --calib-path /local/shared_with_docker/images/ --yaml hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov8s.yaml --start-node-names images --classes 1 --hw-arch hailo8
<Hailo Model Zoo INFO> Start run for network yolov8s ...
<Hailo Model Zoo INFO> Initializing the hailo8 runner...
[info] Restored ONNX model yolov8s (completion time: 00:00:00.22)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.77)
[info] Start nodes mapped from original model: 'images': 'yolov8s/input_layer1'.
[info] End nodes mapped from original model: '/model.22/cv2.0/cv2.0.2/Conv', '/model.22/cv3.0/cv3.0.2/Conv', '/model.22/cv2.1/cv2.1.2/Conv', '/model.22/cv3.1/cv3.1.2/Conv', '/model.22/cv2.2/cv2.2.2/Conv', '/model.22/cv3.2/cv3.2.2/Conv'.
[info] Translation completed on ONNX model yolov8s (completion time: 00:00:01.24)
[info] Saved HAR to: /local/workspace/yolov8s.har
[info] Loading model script commands to yolov8s from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8s.alls
[info] Loading model script commands to yolov8s from string
[info] Mixed Precision is done (completion time is 00:00:00.76)
Calibration: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:26<00:00, 2.39entries/s]
[info] Statistics Collector is done (completion time is 00:00:28.84)
[warning] The force_range command has been used, notice that its behavior was changed on this version. The old behavior forced the range on the collected calibration set statistics, but allowed the range to change during the optimization algorithms.
The new behavior forces the range throughout all optimization stages.
The old method could be restored by adding the flag weak_force_range_out=enabled to the force_range command on the following layers ['yolov8s/conv42', 'yolov8s/conv53', 'yolov8s/conv63']
[info] Adaround skipped
127/128 [============================>.] - ETA: 0s - total_distill_loss: 16.7721 - _distill_loss_yolov8s/conv41: 1.0086 - _distill_loss_yolov8s/conv42: 1.3785 - _distill_loss_yolov8s/conv52: 0.6110 - _distill_loss_yolov8s/conv53: 3.1424 - _distill_loss_yolov8s/conv62: 0.4986 - _distill_loss_yolov8s/conv63: 3.9918 - _distill_loss_yolov8s/conv46: 2.2524 - _distill_loss_yolov8s/conv35: 1.6849 - _distill_loss_yolov8s/conv5128/128 [==============================] - ETA: 0s - total_distill_loss: 16.7585 - _distill_loss_yolov8s/conv41: 1.0093 - _distill_loss_yolov8s/conv42: 1.3750 - _distill_loss_yolov8s/conv52: 0.6116 - _distill_loss_yolov8s/conv53: 3.1264 - _distill_loss_yolov8s/conv62: 0.5003 - _distill_loss_yolov8s/conv63: 3.9918 - _distill_loss_yolov8s/conv46: 2.2532 - _distill_loss_yolov8s/conv35: 1.6854 - _distill_loss_yolov8s/conv5128/128 [==============================] - 34s 265ms/step - total_distill_loss: 16.7451 - _distill_loss_yolov8s/conv41: 1.0100 - _distill_loss_yolov8s/conv42: 1.3716 - _distill_loss_yolov8s/conv52: 0.6122 - _distill_loss_yolov8s/conv53: 3.1106 - _distill_loss_yolov8s/conv62: 0.5021 - _distill_loss_yolov8s/conv63: 3.9919 - _distill_loss_yolov8s/conv46: 2.2540 - _distill_loss_yolov8s/conv35: 1.6860 - _distill_loss_yolov8s/conv57: 2.2067
[info] Quantization-Aware Fine-Tuning is done (completion time is 00:09:19.10)
Full Quant Analysis: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 2/2 [02:10<00:00, 65.12s/iterations]
[info] Layer Noise Analysis is done (completion time is 00:02:14.49)
[info] Adding an output layer after conv41
[info] Adding an output layer after conv42
[info] Adding an output layer after conv52
[info] Adding an output layer after conv53
[info] Adding an output layer after conv62
[info] Adding an output layer after conv63
[info] Resources optimization guidelines: Strategy -> GREEDY Objective -> MAX_FPS
[info] Resources optimization params: max_control_utilization=75%, max_compute_utilization=75%, max_compute_16bit_utilization=75%, max_memory_utilization (weights)=75%, max_input_aligner_utilization=75%, max_apu_utilization=75%
Validating context_0 layer by layer (100%)
● Finished
Context:0/0 Iteration 4: Trying parallel mapping...
cluster_0 cluster_1 cluster_2 cluster_3 cluster_4 cluster_5 cluster_6 cluster_7 prepost
worker0 * * * * * * * * V
worker1 * * * * * * * * V
worker2 V V V V V V V V V
worker3 V V V V V V V V V
00:10
Reverts on cluster mapping: 0
Reverts on split failed: 0
[info] Iterations: 4
Reverts on pre-mapping validation: 2
[info] +-----------+---------------------+---------------------+--------------------+
[info] | Cluster | Control Utilization | Compute Utilization | Memory Utilization |
[info] | cluster_0 | 100% | 62.5% | 57% |
[info] | cluster_1 | 100% | 81.3% | 93% |
[info] | cluster_2 | 87.5% | 62.5% | 33.6% |
[info] | cluster_3 | 100% | 87.5% | 41.4% |
[info] | cluster_4 | 100% | 79.7% | 71.9% |
[info] | cluster_5 | 31.3% | 35.9% | 12.5% |
[info] | cluster_6 | 75% | 87.5% | 69.5% |
[info] | cluster_7 | 6.3% | 6.3% | 1.6% |
[info] | Total | 75% | 62.9% | 47.6% |
[info] Successful Mapping (allocation time: 38s)
[info] Compiling context_0...
[info] Bandwidth of model inputs: 9.375 Mbps, outputs: 4.16565 Mbps (for a single frame)
[info] Bandwidth of DDR buffers: 12.5 Mbps (for a single frame)
[info] Bandwidth of inter context tensors: 0.0 Mbps (for a single frame)
[info] Building HEF...
[info] Successful Compilation (compilation time: 22s)
<Hailo Model Zoo INFO> HEF file written to yolov8s.hef
