I am having a weird issue with DFC. If I run it independently, I can parse, optimize and compile my ONNX model without any problem. But if I run it with another program, more precisely, when it is called by another program, I got errors like the below, any idea what caused this? Thanks in advance! – T.T.
Errors:
tensorflow.python.framework.errors_impl.UnimplementedError: Graph execution error:
Detected at node ‘best/conv1/conv_op/Conv2D’ defined at (most recent call last):
UNIMPLEMENTED:  DNN library is not found.
[[{{node best/conv1/conv_op/Conv2D}}]]
More precisely, it happened during calibration of optimization. But again, no issue at all when running the process independently.
Hi @TT2024,
Could it be that in this other program you have installed extra packages within the DFC venv? This could cause compatibility issues.
Hi @nina-vilela ,
Thanks for your response! Right, there is some conflict – it seems another library changed some environmental variable which the hailo DFC libs don’t like. But it’s hard to solve it. So for now I just don’t run them in the same python virtual environment.
How did you solve this DNN problem?
Hi @user95, as I mentioned in the previous post, it seems another library changed some environmental variable which the hailo DFC libs don’t like. So I just don’t run them in the same python virtual environment. I haven’t encountered such an issue when running DFC in its own python virtual environment.
