This is the full error message:
Epoch 1/4
File “/home/admin/dani/4_optimization.py”, line 21, in
runner.optimize(calib_dataset_path)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2128, in optimize
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1970, in _optimize
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1125, in full_quantization
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1319, in _full_acceleras_run
optimization_flow.run()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 306, in wrapper
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 335, in run
step_func()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 250, in wrapped
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 111, in parent_wrapper
hailo_model_optimization.acceleras.utils.acceleras_exceptions.SubprocessTracebackFailure: Subprocess failed with traceback
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 73, in child_wrapper
func(self, *args, **kwargs)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 360, in step2
self.post_quantization_optimization()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 422, in post_quantization_optimization
self._finetune()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 712, in _finetune
finetune.run()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py”, line 54, in run
return super().run()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py”, line 150, in run
self._run_int()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/finetune/qft.py”, line 387, in _run_int
self.run_qft(self._model_native, self._model, metrics=self.metrics)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/finetune/qft.py”, line 507, in run_qft
self.main_train_summary_per_epoch = qft_distiller.fit(
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/keras/utils/traceback_utils.py”, line 70, in error_handler
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/tensorflow/python/eager/execute.py”, line 52, in quick_execute
tensors = pywrap_tfe.TFE_Py_Execute(ctx._handle, device_name, op_name,
tensorflow.python.framework.errors_impl.InternalError: Graph execution error:
Detected at node ‘update_1_1/StatefulPartitionedCall’ defined at (most recent call last):
step_func()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 94, in parent_wrapper
proc.start()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/multiprocessing/process.py”, line 121, in start
self._popen = self._Popen(self)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/multiprocessing/context.py”, line 224, in _Popen
return _default_context.get_context().Process._Popen(process_obj)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/multiprocessing/context.py”, line 281, in _Popen
return Popen(process_obj)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/multiprocessing/popen_fork.py”, line 19, in init
self._launch(process_obj)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/multiprocessing/popen_fork.py”, line 71, in _launch
code = process_obj._bootstrap(parent_sentinel=child_r)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/multiprocessing/process.py”, line 314, in _bootstrap
self.run()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/multiprocessing/process.py”, line 108, in run
self._finetune()
finetune.run()
self._run_int()
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/keras/utils/traceback_utils.py”, line 65, in error_handler
return fn(*args, **kwargs)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/keras/engine/training.py”, line 1685, in fit
tmp_logs = self.train_function(iterator)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/keras/engine/training.py”, line 1284, in train_function
return step_function(self, iterator)
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/keras/engine/training.py”, line 1268, in step_function
outputs = model.distribute_strategy.run(run_step, args=(data,))
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/keras/optimizers/optimizer.py”, line 1250, in _distributed_apply_gradients_fn
distribution.extended.update(
File “/home/admin/anaconda3/envs/conda_env/lib/python3.10/site-packages/keras/optimizers/optimizer.py”, line 1245, in apply_grad_to_update_var
return self._update_step_xla(grad, var, id(self._var_key(var)))
Node: ‘update_1_1/StatefulPartitionedCall’
step_func()
proc.start()
self.run()
self._finetune()
finetune.run()
self._run_int()
step_func()
proc.start()
self.run()
self._finetune()
finetune.run()
self._run_int()
3 root error(s) found.
(0) INTERNAL: libdevice not found at ./libdevice.10.bc
[[{{node update_1_1/StatefulPartitionedCall}}]]
[[update_2_144/AssignAddVariableOp/_2781]]
[[group_deps/_2789]]
(1) INTERNAL: libdevice not found at ./libdevice.10.bc
(2) INTERNAL: libdevice not found at ./libdevice.10.bc
0 successful operations.
0 derived errors ignored. [Op:__inference_train_function_582293]
