When running GStreamer pipelines the caps for the components including the camera are automatically negotiated. This will often result in a working pipeline but sometimes it is not exactly what you may want. You may want to chose a different video format provided by your camera.
So, how can we find out what formats are supported by the camera?
The TAPPAS application use the v4l2 / Video4Linux driver to support many cameras.
There is a tool available that can list all formats supported by v4l2 devices. You may need to install the following package.
sudo apt install v4l-utils
You can list all v4l2 devices with:
v4l2-ctl --list-devices
Example output
Logitech BRIO (usb-0000:00:14.0-2):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
Note, not all of these devices are video outputs.
The following command will list all formats supported by a v4l2 device.
v4l2-ctl -d /dev/video0 --list-formats
Example output
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
[1]: 'MJPG' (Motion-JPEG, compressed)
[2]: 'NV12' (Y/CbCr 4:2:0)
The extended list will provide more detailed information about a v4l2 device.
v4l2-ctl -d /dev/video0 --list-formats-ext
Example output
Type: Video Capture
[0]: 'MJPG' (Motion-JPEG, compressed)
Interval: Discrete 0.033s (30.000 fps)
[1]: 'YUYV' (YUYV 4:2:2)
Interval: Discrete 0.100s (10.000 fps)
Note that in this example the YUYV format runs only at 10 fps compared to the MJPG format 30 fps at the maximum resolution.
