When using a USB camera as an input a pipeline which is running at a high frame rate is running on a low frame rate 10-15 fps.
What am I doing wrong?
What is the problem?
Most USB cameras are not able to run at FPS larger than 15 fps with YUY2 output for resolutions larger than VGA. This is due to limited bandwidth on the USB interface. Running at high resolution with high FPS on raw video adds up quickly to high bandwidth requirements.
How to check my cameraās available modes?
There are multiple tools available to get the available modes of a camera on Ubuntu. Here are some methods you can use:
- Using GStreamer
gst-device-monitor-1.0
This command will list all multimedia devices and their capabilities. Look for your camera and its supported modes. It can be installed using:
sudo apt-get install gstreamer1.0-tools
- Using v4l2-ctl (Video4Linux2 Control)
v4l2-ctl --list-formats-ext -d /dev/video0
This tool can be installed using:
sudo apt-get install v4l-utils
Here is an example output: (Of my laptopās built-in cameraā¦)
v4l2-ctl --list-formats-ext -d /dev/video2
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'MJPG' (Motion-JPEG, compressed)
Interval: Discrete 0.033s (30.000 fps)
[1]: 'YUYV' (YUYV 4:2:2)
Interval: Discrete 0.100s (10.000 fps)
You can see that trying to get 720p raw YUYV output will be limited to 10fps.
How to use the āMJPGā mode in GStreamer?
To use the āMJPGā mode in GStreamer, you can add a caps filter requiring a specific video encoding.
Letās take a simple pipeline running from the camera:
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw, width=1280, height=720 ! \
videoconvert ! fpsdisplaysink
This pipeline will run at 10 fps with the camera we are testing.
To āforceā the camera to use āMJPGā, weāll add specific caps:
gst-launch-1.0 v4l2src device=/dev/video2 ! image/jpeg, width=1280, height=720 ! \
decodebin ! videoconvert ! fpsdisplaysink
Note that 2 changes were required:
- Add the image/jpeg format caps term.
- Now, we need to add a decode stage in order to use the video. In this case, I used decodebin autoplugger; you can also use a specific plugin like jpegdec, for example.
Is there a downside?
Well, yes. Using an encoded stream requires decoding resources on the host. If the host is very weak, the āencodingā might become a worse bottleneck than the USB bandwidth, leading to a worse frame rate. However, in most hosts, this will allow you to reach higher frame rates than using the cameraās raw video mode.
If you found this (or other posts) useful, please hit the
button to help promote it to more people. Have insights, corrections, or questions? Share your thoughts in the comments!
