While trying to download the compiled yolov8n_seg.hef fromyolov8n_seg.hef I am getting the following error:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
AccessDenied
Access Denied
JG2JK5RX35TCCJCG
HR7DXYOjbm7bpDeVVCe3d8vUy6ncsfonAqr7/bjHxmw6zDPtlAw7iSaWmX4***************=(***** used for obfuscation)
Kindly help me out if possible, i’ll be truly grateful.
Thank you
Hi @deepeshbhardwaj2003,
You’re right, it seems there is an issue with downloading the HEF for the yolov8n_seg
model. However, if you need to use it soon, I recommend downloading the pretrained model available in the Model Zoo repository. You can find it at the following link: Model Zoo - Instance Segmentation. This model is available in ONNX format, and you can then use the Dataflow Compiler to convert it to HEF while the download issue is being resolved.
I hope this helps!
Best regards,
Oscar Mendez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.ai
Developers wiki: Hailo AI Platform Guide
Website: www.ridgerun.ai
