My setup is as follows:
- Dev environment : MacOS
- Hailo hardware: 8 running on raspberry pi 5
I’m trying to install the DFC or SW suite but the requirements are not clear. If I try to install in a ubuntu docker container running on my mac will that work?
Do I have to have the hailo8 installed on the machine i’m installing it on?
There is a separate set of requirements for nvidia for hardware emulation. I can’t see what this is referring to. Can I do everything I need without this.
I’ve been trying for 2 days to install the DFC on a docker container on my mac and I’m not sure it’s a hardware issue or my internet connection (I’m currently away from home and my network speed is the worst I’ve ever seen) The first issue I have is when it get’s to the tensorflow-2.12.0-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl step it frequently hits ReadTimeoutError(self._pool, None, "Read timed out.") because the connection is so shabby. But the other issue I keep facing is that many of the packages it tries to install hit this issue:
Downloading types_python_dateutil-2.9.0.20241206-py3-none-any.whl (14 kB)
ERROR: THESE PACKAGES DO NOT MATCH THE HASHES FROM THE REQUIREMENTS FILE. If you have updated the package versions, please update the hashes. Otherwise, examine the package contents carefully; someone may have tampered with them.
unknown package:
Expected sha256 357d9d2851188a8d27ee195345b4d175cad970150d1344ba9d9fcc4bf2b68336
Got 06c834bcbf503ac1848afc2e2d70543e8dfffa42783d6487cbf74005d136e78f
So I have to find a work around and start all over again (with my slow internet).
So in summary:
- Can the host machine for docker be a Mac?
- Do I need an nvidia GPU (if so what for)?
- Do I need the hailo chip to be connected to the host?
- What are these HASH issues being caused by when installing?
