Hi Hailo Community,
I’m encountering an issue while running the rpiExamples on a Raspberry Pi 5 with the Hailo-8 PCIe module (26 TOPS). I’m following the instructions exactly as described in the documentation, and I’m using the official Raspberry Pi 5 power supply (5V/5A).
After a few hundred frames of successful detection, I start receiving the following warnings and errors:
the comand is:
python basic_pipelines/detection.py --input usb
Frame count: 295
Detection: ID: 1 Label: person Confidence: 0.95
Frame count: 300
Detection: ID: 1 Label: person Confidence: 0.96
[HailoRT] [warning] Failed to acquire buffer because the buffer pool is empty. This could be caused by uneven reading and writing speeds, with a short user-defined timeout. (timeout=10000ms)
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_TIMEOUT(4) - Failed to acquire buffer with status=HAILO_TIMEOUT(4)
[HailoRT] [error] CHECK failed - PreInferEl1yolov8m/input_layer1 (H2D) failed with status=HAILO_TIMEOUT(4) (timeout=10000ms)
[HailoRT] [error] CHECK failed - Got timeout in `wait_for_async_ready` (10000ms) - the edge 'yolov8m/yolov8_nms_postprocess' could not receive 1 transfer-requests
dmesg | grep -i hailo
[ 3.130849] hailo: Init module. driver version 4.20.0
[ 3.130985] hailo 0001:01:00.0: Probing on: 1e60:2864...
[ 3.130992] hailo 0001:01:00.0: Probing: Allocate memory for device extension, 13184
[ 3.131011] hailo 0001:01:00.0: enabling device (0000 -> 0002)
[ 3.131018] hailo 0001:01:00.0: Probing: Device enabled
[ 3.131045] hailo 0001:01:00.0: Probing: mapped bar 0 - 000000000ec16bcd 16384
[ 3.131053] hailo 0001:01:00.0: Probing: mapped bar 2 - 000000003a646a55 4096
[ 3.131056] hailo 0001:01:00.0: Probing: mapped bar 4 - 00000000fdf8f448 16384
[ 3.131059] hailo 0001:01:00.0: Probing: Force setting max_desc_page_size to 4096 (recommended value is 16384)
[ 3.131072] hailo 0001:01:00.0: Probing: Enabled 64 bit dma
[ 3.131074] hailo 0001:01:00.0: Probing: Using userspace allocated vdma buffers
[ 3.131080] hailo 0001:01:00.0: Disabling ASPM L0s
[ 3.131085] hailo 0001:01:00.0: Successfully disabled ASPM L0s
[ 3.131209] hailo 0001:01:00.0: Writing file hailo/hailo8_fw.bin
[ 3.258164] hailo 0001:01:00.0: File hailo/hailo8_fw.bin written successfully
[ 3.258171] hailo 0001:01:00.0: Writing file hailo/hailo8_board_cfg.bin
[ 3.258195] Failed to write file hailo/hailo8_board_cfg.bin
[ 3.258197] hailo 0001:01:00.0: File hailo/hailo8_board_cfg.bin written successfully
[ 3.258198] hailo 0001:01:00.0: Writing file hailo/hailo8_fw_cfg.bin
[ 3.258205] Failed to write file hailo/hailo8_fw_cfg.bin
[ 3.258206] hailo 0001:01:00.0: File hailo/hailo8_fw_cfg.bin written successfully
[ 3.356565] hailo 0001:01:00.0: NNC Firmware loaded successfully
[ 3.356570] hailo 0001:01:00.0: FW loaded, took 225 ms
[ 3.368738] hailo 0001:01:00.0: Probing: Added board 1e60-2864, /dev/hailo0
[ 561.666395] hailo 0001:01:00.0: Failed writing fw control to pcie
[ 1071.016306] hailo 0001:01:00.0: hailo_nnc_driver_down, timeout waiting for shutdown response (timeout_ms=5)
It seems like the inference pipeline hits a bottleneck and the buffer pool is depleted, leading to timeouts.
My setup:
- Raspberry Pi 5 (8GB)
- Hailo-8 PCIe module (26 TOPS)
- Official Raspberry Pi 5 power supply
- Running
basic_pipelines/detection.pyvia:
python3 basic_pipelines/detection.py --input usb
Has anyone encountered this issue?
Is there a recommended way to:
- Limit the frame rate to avoid overwhelming the pipeline?
- Tune internal buffer sizes or timeouts?
- Properly reset or recover the PCIe device after this happens?
Thanks in advance for your help!
