Hi Team ,
I want meta-hailo-tappas layer for Mickledore , I am using hailo8 with stm32mp and my bsp only works with scarthgap and mickledore , so i was using mickledore but foud that there is no tappas layer for it .
Any help would be appreciated
Hi Team ,
Hey @Mayur_Dongre,
What do you mean by “tappas layer”? Are you referring to the tappas-core functions? If so, you can compile it from the source code in this repo: GitHub - hailo-ai/tappas: High-performance, optimized pre-trained template AI application pipelines for systems using Hailo devices
If that’s not what you’re talking about and you mean the meta-hailo-tappas layer instead, I’ll need to see the logs to understand what error you’re encountering.
Hey Omria,
when i clone GitHub - hailo-ai/meta-hailo: Meta Hailo and switch to mickledore branch there is no meta-hailo-tappas repo , i was talking about this.
TAPPAS is not supported for Mickledore only HailoRT is.
GitHub - meta-hailo - Mickledore-v3.32.0
Unfortunately, sometimes engineering resources limit what we can support and validate. We do support meta-hailo-tappas for Kirkstone at this is an LTS version.
GitHub - meta-hailo - Kirkstone-v3.32.0
We currently plan to support Yocto Scarthgap for Hailo-8 with the next release.
Hi Klausk,
Sure Yocto Scarthgap will too do the work , will wait for the release.
