Hailo software suite and Tappas setup
I’ve using hailo earlier, but now I’m setting it up from scratch along with 2 rtx 3090 gpus. So I installed the software suite and the packages that were mentioned, but upon reading the docs, came to know that tappas is not present entirely, just a single working example is there.
I then downloaded the zip from github, and did
skip-hailort from false to true
since it was search for a the hailort folder which was not even present, after that I’m facing some other errors as well.
Can somebody post the steps to install it from scratch, because earlier it was quite easy, but now since tappas is not a part of the software, I’m facing issues.
@omria please have a look at this, would really appreciate your help.
Hey @Utsav_Sharma,
If you’re currently using an older version, I’d suggest sticking with what you have since we’ve deprecated the tappas apps. However, if you don’t mind making the switch, I’d recommend working with GitHub - hailo-ai/hailo-apps-infra instead.
Hope this helps!
