I installed a Hailo8 PCIe card on a EQ14 N150. On it I have installed Debian 13 in which I compiled the drivers 4.21 and running Frigate container.
In the past days I found several times the system freezed and I had to power off to restart.
I see that everytime I start Frigate I have several thousand lines of warnings all similar to this:
------------[ cut here ]------------
WARNING: CPU: 3 PID: 3250 at include/linux/rwsem.h:80 find_vma+0x59/0x70
Modules linked in: tls nf_conntrack_netlink xt_nat xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge xt_set ip_set nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype nft_compat nf_tables libcrc32c xfrm_user xfrm_algo overlay 8021q garp stp mrp llc snd_hda_codec_realtek snd_hda_codec_generic snd_sof_pci_intel_tgl snd_hda_scodec_component snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel soundwire_generic_allocation soundwire_cadence intel_rapl_msr snd_sof_intel_hda_common intel_rapl_common x86_pkg_temp_thermal snd_soc_hdac_hda nls_ascii snd_sof_intel_hda_mlink nls_cp437 snd_sof_intel_hda vfat intel_powerclamp snd_hda_codec_hdmi fat coretemp snd_sof_pci snd_sof_xtensa_dsp snd_sof kvm_intel snd_sof_utils snd_soc_acpi_intel_match snd_soc_acpi i915 iwlmvm soundwire_bus kvm snd_soc_avs mac80211 snd_soc_hda_codec snd_hda_ext_core snd_soc_core irqbypass crct10dif_pclmul ghash_clmulni_intel snd_compress snd_pcm_dmaengine sha512_ssse3 libarc4 snd_hda_intel sha256_ssse3
snd_intel_dspcfg sha1_ssse3 snd_intel_sdw_acpi iwlwifi btusb snd_hda_codec drm_buddy drm_display_helper btrtl aesni_intel btintel snd_hda_core gf128mul btbcm crypto_simd btmtk cryptd snd_hwdep bluetooth cec snd_pcm rc_core hailo_pci(OE) cfg80211 rapl ttm evdev intel_cstate snd_timer wmi_bmof intel_uncore mei_me drm_kms_helper snd ee1004 pcspkr mei soundcore rfkill i2c_algo_bit igen6_edac intel_pmc_core intel_vsec pmt_telemetry pmt_class acpi_pad acpi_tad button drm configfs efi_pstore nfnetlink efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic spi_pxa2xx_platform dw_dmac dw_dmac_core spi_pxa2xx_core xhci_pci iTCO_wdt intel_pmc_bxt xhci_hcd iTCO_vendor_support nvme watchdog usbcore crc32_pclmul i2c_i801 crc32c_intel i2c_smbus nvme_core igc intel_lpss_pci intel_lpss nvme_auth idma64 usb_common fan video wmi pinctrl_alderlake
CPU: 3 UID: 0 PID: 3250 Comm: frigate.detecto Tainted: G W OE 6.12.48+deb13-amd64 #1 Debian 6.12.48-1
Tainted: [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Hardware name: AZW EQ/EQ, BIOS TWEQF003 03/31/2025
RIP: 0010:find_vma+0x59/0x70
Code: c7 40 48 c7 c2 ff ff ff ff 48 89 e6 e8 30 d8 8f 00 48 8b 54 24 08 65 48 2b 14 25 28 00 00 00 75 0d 48 83 c4 10 c3 cc cc cc cc <0f> 0b eb d0 e8 9e 42 97 00 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f
RSP: 0018:ffffb845079cb9b0 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 00007f66c6b78000 RCX: 0000000000000000
RDX: 0000000000000080 RSI: 00007f66c6b78000 RDI: ffff9f7e0006d800
RBP: ffffb845079cba48 R08: 0000000000000080 R09: ffff9f7e0232bb80
R10: ffffb845079cb9c8 R11: 0000000000000000 R12: 0000000000000000
R13: ffff9f7e0232bb80 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f66ae1ca6c0(0000) GS:ffff9f816fb80000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 00007f66b598c140 CR3: 00000001076d8002 CR4: 0000000000f72ef0
PKRU: 55555554
Call Trace:
hailo_vdma_buffer_map+0x90/0x500 [hailo_pci]
hailo_vdma_buffer_map_ioctl+0xc0/0x1b0 [hailo_pci]
hailo_pcie_fops_unlockedioctl+0x1ca/0x490 [hailo_pci]
__x64_sys_ioctl+0x91/0xd0
do_syscall_64+0x82/0x190
? __iommu_map+0x129/0x270
? arch_exit_to_user_mode_prepare.isra.0+0x16/0xa0
? syscall_exit_to_user_mode+0x37/0x1b0
? do_syscall_64+0x8e/0x190
? iommu_map_sg+0x10e/0x1c0
? iommu_dma_map_sg+0x28b/0x420
? __finalise_sg.isra.0+0xfb/0x1b0
? __dma_map_sg_attrs+0x117/0x190
? dma_map_sg_attrs+0xe/0x20
? hailo_vdma_buffer_map+0x304/0x500 [hailo_pci]
? hailo_vdma_buffer_map_ioctl+0x112/0x1b0 [hailo_pci]
? up+0x56/0xa0
? hailo_pcie_fops_unlockedioctl+0x12b/0x490 [hailo_pci]
? __count_memcg_events+0x53/0xf0
? count_memcg_events.constprop.0+0x1a/0x30
? handle_mm_fault+0x1bb/0x2c0
? do_user_addr_fault+0x36c/0x620
entry_SYSCALL_64_after_hwframe+0x76/0x7e
RIP: 0033:0x7f66e565cd1b
Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1c 48 8b 44 24 18 64 48 2b 04 25 28 00 00
RSP: 002b:00007f66ae1c6870 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00007f66ae1c6b70 RCX: 00007f66e565cd1b
RDX: 00007f66ae1c6920 RSI: 00000000c0287604 RDI: 0000000000000021
RBP: 0000000019a4b2b0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000001000 R11: 0000000000000246 R12: 0000000019a4b340
R13: 0000000019a4b368 R14: 00007f66c6b78000 R15: 0000000019a4b2b0
—[ end trace 0000000000000000 ]—
or this:
RSP: 0018:ffffb845079cbd80 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 00007f66a62b4000 RCX: 0000000000000000
RDX: 0000000000000080 RSI: 00007f66a62b4000 RDI: ffff9f7e0006d800
RBP: ffffb845079cbe18 R08: 0000000000000080 R09: ffff9f7e01f39a80
R10: ffffb845079cbd98 R11: 00000000ffffffff R12: 0000000000000000
R13: ffff9f7e01f39a80 R14: 0000000000000000 R15: 0000000000000000
CR2: 00007f66b59353e0 CR3: 00000001076d8002 CR4: 0000000000f72ef0
PKRU: 55555554
Call Trace:
RSP: 002b:00007f66ae1c8510 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00007f66ae1c8810 RCX: 00007f66e565cd1b
RDX: 00007f66ae1c85c0 RSI: 00000000c0287604 RDI: 0000000000000021
Missed 8 kernel messages
Missed 27 kernel messages
Missed 20 kernel messages
Missed 4 kernel messages
? up+0x56/0xa0
Missed 12 kernel messages
R10: 0000000000000780 R11: 0000000000000246 R12: 0000000019a4b340
Missed 6 kernel messages
Missed 5 kernel messages
RSP: 0018:ffffb845079cba20 EFLAGS: 00010246
Missed 47 kernel messages
Missed 2 kernel messages
Missed 29 kernel messages
Missed 17 kernel messages
RAX: 0000000000000000 RBX: 00007f66c6b5b000 RCX: 0000000000000000
Missed 19 kernel messages
Missed 10 kernel messages
Missed 7 kernel messages
RBP: ffffb845079cbc98 R08: 0000000000000080 R09: ffff9f7e54887600
Missed 33 kernel messages
Missed 11 kernel messages
Missed 9 kernel messages
RSP: 0018:ffffb845079cbd70 EFLAGS: 00010246
Missed 14 kernel messages
Missed 23 kernel messages
Missed 1 kernel messages
Missed 22 kernel messages
R13: 0000000019a4b368 R14: 00007f66c6b56000 R15: 0000000019a4b2b0
Missed 3 kernel messages
RSP: 0018:ffffb845079cbb30 EFLAGS: 00010246
Missed 21 kernel messages
RSP: 0018:ffffb845079cbc40 EFLAGS: 00010246
Missed 15 kernel messages
RSP: 0018:ffffb845079cbb70 EFLAGS: 00010246
Missed 30 kernel messages
and continue for several hundreds lines.
After one freze I found this at the end of logs:
list_del corruption. next->prev should be ffffe136c74b5dc8, but was f7ffe136c74b5dc8. (next=ffffe136c74b5d48)
kernel BUG at lib/list_debug.c:65!
BUG: unable to handle page fault for address: 000003fffffffff8
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
Any idea of what the matter is?
