- Check what Python version are already installed -
ls -ls /usr/bin/python* - If the desired Python version is not installed, install it -
sudo apt install python3.X - In case of
Couldn't find any package by glob 'Python-X.X.X':
sudo add-apt-repository ppa:deadsnakes/ppa
- Create the alternatives where X is the desired and Y is the main one:
sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.X 1
sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.Y 2
sudo update-alternatives --config python3
## Here you'll get this print to the screen -
## Press <enter> to keep the current choice[*], or type selection number:
## Type the number represeting the desired version (in out case X is 1) and press ENTER.
Example:
sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.8 1
sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.6 2
Press <enter> to keep the current choice[*], or type selection number: 1
And we'll get this print:
pdate-alternatives: using /usr/bin/python3.8 to provide /usr/bin/python3 (python3) in manual mode
- Install the relevant virtualenv -
sudo apt install python3.X-venv - Create the virtualenv -
python3.X -m venv ENV_NAME - Enter the virtualenv -
. /path_to_venv_folder/bin/activate
