Issue with Importing hailort 4.20.0 Module in Python 3.10.4 Environment
Hello Community!
I am facing an issue where the hailort module is not recognized in my Python environment, despite being installed correctly. Here is a detailed breakdown of the issue and the steps I’ve taken so far:
Environment Setup:
I am using pyenv to manage Python versions, with a virtual environment hailoconv set to Python 3.10.4.
The environment is activated successfully (pyenv activate hailoconv), and I have verified this by running python --version (which shows Python 3.10.4).
hailort Installation:
I installed hailort version 4.20.0 appropriate for python 3.10 using .whil file hailort-4.20.0-cp310-cp310-linux_aarch64.whl. Suitable for my system arch.
Confirmed the installation with pip show hailort, which shows that version 4.20.0 is installed in the correct path:
/home/my/.pyenv/versions/3.10.4/envs/hailoconv/lib/python3.10/site-packages.
Issue Encountered:
Despite the successful installation of hailort, when I attempt to import the module in Python (import hailort), I receive the following error:
ModuleNotFoundError: No module named 'hailort'
I verified the Python executable being used with which python, which correctly points to
/home/my/.pyenv/versions/3.10.4/envs/hailoconv/bin/python
I have tried importing the module directly in a Python session using the following:
import hailort
But it still returns the ModuleNotFoundError.
Attempts to Resolve:
I have tried deactivating and reactivating the environment (pyenv deactivate / pyenv activate hailoconv).
Reinstalled hailort by running pip uninstall hailort followed by pip install hailort.
Checked the PYTHONPATH environment variable and ensured it includes the correct path to the site-packages directory for the virtual environment.
Could you assist me in resolving this issue? The installation seems correct, but the module is not being recognized in Python, and I have exhausted basic troubleshooting steps.
I am aiming to use the script to run .hef custom built model on raspy5 with a hailo hat.
Thank you for your support.
Hey @bublinimuzini,
Let me clarify our Python package imports. Instead of hailort, you should be using:
import hailo
import hailo_platform
from hailo_platform import (HEF, VDevice, FormatType, HailoSchedulingAlgorithm)
from hailo_platform import (HEF, Device, VDevice, HailoStreamInterface, ConfigureParams,
    InputVStreamParams, OutputVStreamParams, InputVStreams, OutputVStreams, FormatType)
Try these imports and let us know if you need any further assistance!
Best regards,
Omria
Thank you for the reply Omria! i’ll try it out.
The issue still persists… are there any debugging steps you would recommend?
I tried to run the script outside the env. and i got
  File "/home/abela/Documents/superhailo/inference.py", line 4, in <module>
    import hailo
ImportError: libgsthailometa.so.3: cannot open shared object file: No such file or directory
Hi omria,
The script worked with just importring hailo_platfrom and skipping hailo import.
