Has anyone already worked with quantizing SiamRPN for Hailo-8? Are there perhaps any guides available?
Hey @An_ti11
we don’t officially support SiamRPN, but here’s a basic guide to get started with any custom model on Hailo-8:
Setup and Compile SiamRPN
Export your PyTorch model to ONNX
Usetorch.onnx.export()with proper input/output names. -
Translate the ONNX model using Hailo SDK
UseClientRunner().translate_onnx_model(...)with the correct input shape. -
Apply custom quantization parameters
- Use
quantization_param(...)for precision per layer. - Set
quantization_groupsandforce_range_outas needed.
- Use
Run model calibration
Use representative data and callmodel_optimization_config(...). -
Run model compilation
Use ClientRunner().compile()
Tips for SiamRPN
- Ensure cross-correlation (group conv) layers export correctly to ONNX.
- Watch for reshape/transpose issues – they often break shape inference.
- Quantization is tricky in dense and upsampling layers – tune carefully.
