SDK version: Hailo AI Software Suite 2024-10
I encountered an error while running ClientRunner.translate_onnx_model() on a network that includes an Expand-Concat layer. To investigate the issue, I created a simple code snippet that reproduces the problem, which I’ve included below.
import torch
import torch.nn as nn
import onnx
from onnxsim import simplify
class SimpleONNXStyleNetwork(nn.Module):
def __init__(self):
super(SimpleONNXStyleNetwork, self).__init__()
def forward(self, x):
gathered = x[:,0,:]
unsqueezed = gathered.unsqueeze(1)
expanded = unsqueezed.expand(-1, 576, -1)
sliced = expanded[:, 0:576, :]
concatenated = torch.cat((expanded, sliced), dim=2)
return concatenated
def main():
dummy_input = torch.randn(1, 577, 768)
model = SimpleONNXStyleNetwork()
model.eval()
# demo
output = model(dummy_input)
print("Output shape:", output.shape)
onnx_path = 'model.onnx'
torch.onnx.export(model, dummy_input, onnx_path,
export_params=True,
training=torch.onnx.TrainingMode.EVAL,
input_names=["input.1"], # default: input.1
do_constant_folding=False,
opset_version=13)
onnx_model = onnx.load(onnx_path)
#onnx_model = onnx.shape_inference.infer_shapes(onnx_model)
onnx_model, check = simplify(onnx_model)
onnx.save(onnx_model, onnx_path)
print("output ONNX file")
chosen_hw_arch = 'hailo8'
onnx_model_name = 'model'
end_node_names = ['26']
hn, npz = runner.translate_onnx_model(onnx_path, onnx_model_name,
start_node_names=['input.1'],
end_node_names=end_node_names,
net_input_shapes={'input.1': [1, 577, 768]})
if __name__ == '__main__':
main()
Error Message:
File "/home/hailo/work/hailo-problem/my_network.py", line 62, in <module>
main()
File "/home/hailo/work/hailo-problem/my_network.py", line 55, in main
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1158, in translate_onnx_model
parser.translate_onnx_model(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 276, in translate_onnx_model
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 316, in _parse_onnx_model_to_hn
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 367, in parse_model_to_hn
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py", line 83, in convert_model
self._create_layers()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 40, in _create_layers
self._add_direct_layers()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 163, in _add_direct_layers
raise ParsingWithRecommendationException(
UnexpectedNodeError in op /Expand: Unexpected node /Expand (Expand)
UnsupportedModelError in op /Concat: In vertex /Expand the constant value shape (3,) must be broadcastable to the output shape [1, 768, 576]
Please try to parse the model again, using these end node names: /Unsqueeze
The shape [1, 768, 576] reported in the error does not match the expected shape [1, 576, 768] in the model structure.
I appreciate any guidance you can provide.
Best regards.
