import threading
import subprocess
import os
import signal
from mrr2 import run_radar
stop_flag = False
def run_yolo_pipeline():
return subprocess.Popen(
"source setup_env.sh && python3 detection_yr.py --input usb --show-fps --frame-rate 30",
shell=True,
executable="/bin/bash",
preexec_fn=os.setsid
def run_radar_pipeline():
global stop_flag
while not stop_flag:
run_radar()
if __name__ == "__main__":
radar_thread = threading.Thread(target=run_radar_pipeline)
radar_thread.start()
yolo_proc = run_yolo_pipeline()
try:
yolo_proc.wait()
except KeyboardInterrupt:
print("Shutting down...")
stop_flag = True
radar_thread.join()
try:
os.killpg(os.getpgid(yolo_proc.pid), signal.SIGTERM)
except Exception as e:
print("Error killing YOLO process:", e)
def update():
global buffer, radar_points
points = []
if ser.in_waiting:
buffer += ser.read(ser.in_waiting)
ptr = buffer.find(magic_word)
if ptr != -1:
try:
session = MRR_session(buffer, ptr)
messages = session.get_dict()
print(messages)
for msg in messages['messages']:
header = msg.get("header", {})
if header.get("numTLVs", 0) > 0:
for tlv in msg.get("body", []):
data = tlv.get('body', {}).get('data', [])
timestamp = time.time()
for entry in data:
x = entry.get('x')
y = entry.get('y')
xd = entry.get('xd')
yd = entry.get('yd')
if x is not None and y is not None:
x_scaled = x / (2 ** 7)
y_scaled = y / (2 ** 7)
point = {
"timestamp": timestamp,
"x": x_scaled,
"y": y_scaled,
"z": 1.0,
"xd": xd,
"yd": yd
points.append(point)
buffer = b""
print("Incomplete or corrupt message:", e)
def run_radar():
update()
import gi
from gi.repository import Gst
import hailo
from hailo_apps.hailo_app_python.core.common.buffer_utils import get_caps_from_pad
from hailo_apps.hailo_app_python.core.gstreamer.gstreamer_app import app_callback_class
from hailo_apps.hailo_app_python.apps.detection.detection_pipeline import GStreamerDetectionApp
def __init__(self):
super().__init__()
buffer = info.get_buffer()
if buffer is None:
return Gst.PadProbeReturn.OK
user_data.increment()
frame = None
user_data.use_frame = True
for detection in detections:
#some processing
try:
app.run()
print("Interrupted by user. Saving detections...")
print("Unexpected error:", e)
I’m working on a sensor fusion project where the radar outputs target positions and speeds at 15 FPS, and the camera runs YOLO object detection at 30 FPS. I’ve managed to run both in parallel, with the radar running in a thread and YOLO running as a separate subprocess, and also saved the results separately as arrays. Above is the threading script, radar script, yolo script from top to bottom
My goal is to achieve real time fusion by taking the most recent radar points from the update() function, which reads radar data from the serial port, decodes it, and outputs a timestamped list of scaled positions and velocities, and pass them to the YOLO subprocess for fusion processing.
Is this possible? What would be a robust method to share this latest radar data with the YOLO subprocess?
