How do i run yolov8 object detection and segmentation parallel?
We have one yolov8 segmenetation model for lane detection, and other object detection model for traffic lights and crosswalk.
We are on raspberry pi5 running ubuntu 24.04 and with the updated hailo application examples we got it working with driver 4.22, object detection works fine.
But we need to run two models, so can i run them parallely, if so is there up to date information about this? Or do I have to combine them to one hef file using hailo model zoo like i did for my object detection code?
Which is the best way?
Hi @Jeongmo_Kim
You can use DeGirum PySDK for such use cases. In fact, a lot of users have been able to develop such applications that use multiple models either in series or in parallel. You can see this for an example: Running multiple models independently
I was getting errors saying Hailo device is NOT supported or NOT recognized properly.
And it says DeGirum PySDK supports Hailo Runtime versions 4.19.0, 4.20.0 and 4.21.0. Ensure your Hailo environment is configured to use one of these versions.
But I need to use 4.22 to work with ubuntu 24.04 so I can’t use this right now
Hi @Jeongmo_Kim
Thanks for checking PySDK out. We will be releasing pySDK 0.18.0 that supports HailoRT4.22 in the next couple of days. I will keep you posted.
So with the updated hailo examples i tweaked it to some extent and built my ros2 packages, where i can utilize hailo8 and have it publish ros2 topics. But the problem is i have to run them in parallel, right now when i try to launch both packages at the same time it says i’m out of physical devices.
I’m running out of time and energy put into this, silly me thought this would be just a little bit harder than running inference on a laptop, turns out its 100x harder and i don’t even know how to run it from here.
There has to be a simple way to allow hailo driver to just allow multiple models to run and just schedule itself, because this is getting out of my hand. Even just implementing the example files to my needs took me almost 2 weeks because of version conflicts and errors, Please give me a simplest guide to make this work.
All working ROS2 packages, i just need them to run at the same time.
What’s running today (high-level)
  • One camera publisher (v4l2_camera), publishing /image_raw (BGR8, 640Ă—480).
  • Two ROS 2 packages:
    1. Lane segmentation (custom YOLOv8-seg HEF).
    2. Object detection (existing Hailo OD package).
Both packages now support subscriber mode (consume /image_raw) as well as a standalone mode (open /dev/video4). For parallel operation we use subscriber mode for both and let the camera node own the device.
1) Lane segmentation package
Key files
  • hailo_lane_seg/lane_core.py
    • LaneEngine (Hailo infer wrapper for lane HEF, FLOAT32 output).
    • postprocess(...) (assembles YOLOv8-seg heads, masks).
    • masks_union_to_fullsize(masks, pad, out_shape) — publishes the union mask built from per-instance masks (de-letterboxed + resized).
    • lane_positions_from_masks(...) — extracts N lane x-positions at a chosen y-ROI.
  • hailo_lane_seg/lane_seg_node.py — subscriber node:
    • Subscribes to /image_raw (handles bgr8, rgb8, yuv422_yuy2).
    • Runs Hailo inference + postprocess on each frame.
    • Publishes:
      • /lane_mask — sensor_msgs/Image mono8 0/255, same size as input.
      • /lane_status — std_msgs/String JSON:
        {"count": N, "lanes_px": [...], "lanes_norm": [...]}
        (no yaw/offset in-node; safe for controllers to compute later).
      • /lane_overlay — optional debug BGR image (off by default).
  • hailo_lane_seg/lane_seg_standalone.py — device grabber (for single-process testing).
    • Fixed clean shutdown (no double rclpy.shutdown()).
Topics & params
  • Topics: /lane_mask, /lane_status, /lane_overlay (optional).
  • Core params (all ROS params):
    • net (HEF path), input_topic (for subscriber mode),
    • conf, mask_thr, nms_iou, min_lanes,
    • yroi (e.g., "0.45,1.0"), bottom_frac, min_pix,
    • publish_overlay (bool), show_window (bool).
  • Optional throttles (easy to add if we want): pub_mask_every, pub_status_every.
2) Object detection package (hailo_infer_status)
What changed
  • Added subscriber mode so OD can consume /image_raw instead of opening the device:
    • New param: input_topic (empty = device mode, non-empty = subscribe).
    • node.py converts Image → BGR and calls the existing per-frame pipeline.
  • Launch now accepts input_topic and passes it through as a parameter.
Pipeline (unchanged logic)
  • Uses your existing HailoInfer (one HEF).
  • Optional ByteTrack if enable_tracking=true.
  • Publishes:
    • /hailo/detections — JSON list of {class_id,label,score,bbox}.
    • /hailo/status, /hailo/ok, /hailo/fps, /hailo/frames.
    • (Overlay is still local window; we can add /od_overlay if needed.)
Hi @Jeongmo_Kim
It looks like you are very close to getting everything to work. If your only obstacle is getting both of them to work at the same time, maybe you just forgot to start the Hailo multi-process service
sudo systemctl enable --now hailort.service # for Ubuntu
Hi @Jeongmo_Kim
New PySDK (version 0.18.0) that supports hailort4.22 has been released: Release Notes | DeGirum Docs
Probably you’re using HailoRT if it is with Hailo Application Examples. You need to enable HailoRT multiprocess service enabled and use multithreading.
Also you need to make changes in the VDevice creation codes.
params.multi_process_service = True
params.group_id = "shared"
self.vdevice = VDevice(params)
But if you’re not really used to HailoRT and multithreading and don’t know what you’re doing, I’d recommend using TAPPAS and GStreamer for parallel inference.
But in the first place, why would you use 2 separated YOLOv8 for your pipeline? You can train 1 single YOLOv8 instance segmentation model for crosswalk, traffic lights and lane detection. If instance information is not really important, lane detection should be handled with semantic segmentation, not with YOLOv8-seg.
Thank you everyone, I have succesfully set up my parallel inference and publishing topic in ros2 environment
It was just simple as suggested,
adding this line under hailo_inference.py
Nothing else since i utilized a lot of the framework already provided with the HailoRT Application examples
Now comese the problem, very slow fps, maybe we are cpu bound?
When running just the object detection model (yolov8s) i get stable 30FPS, hailo utilization at around 25%, but with both enabled their performance is very slow.
Am I doing something wrong with my post processing or something?
Here are some of my codes
import numpy as np, cv2, queue, time
from .hailo_inference import HailoInfer
def sigmoid(x): return 1.0 / (1.0 + np.exp(-x))
def softmax(x, axis=-1):
    x = x - np.max(x, axis=axis, keepdims=True)
    e = np.exp(x)
    return e / np.sum(e, axis=axis, keepdims=True)
def as_nhwc(arr, expect_c):
    if isinstance(arr, np.ndarray) and arr.ndim == 3:
        arr = arr[None, ...]
    if not isinstance(arr, np.ndarray) or arr.ndim != 4:
        raise ValueError("Expected 3D/4D tensor, got {}".format(getattr(arr, "shape", None)))
    n, a, b, c = arr.shape
    if c == expect_c:      return arr
    if a == expect_c:      return arr.transpose(0,2,3,1)
    if b == expect_c:      return arr.transpose(0,3,1,2).transpose(0,2,3,1)
    raise ValueError("Cannot convert to NHWC with C={}, got {}".format(expect_c, arr.shape))
def letterbox_bgr(img, dst_wh):
    dh, dw = dst_wh[1], dst_wh[0]
    h, w = img.shape[:2]
    r = min(dw / w, dh / h)
    nw, nh = int(round(w*r)), int(round(h*r))
    resized = cv2.resize(img, (nw, nh), interpolation=cv2.INTER_LINEAR)
    out = np.zeros((dh, dw, 3), dtype=np.uint8)
    top = (dh - nh) // 2
    left = (dw - nw) // 2
    out[top:top+nh, left:left+nw] = resized
    return out, (top, left)
def xywh2xyxy(x):
    y = x.copy()
    y[:,0] = x[:,0] - x[:,2]/2; y[:,1] = x[:,1] - x[:,3]/2
    y[:,2] = x[:,0] + x[:,2]/2; y[:,3] = x[:,1] + x[:,3]/2
    return y
def nms_cpu(boxes, scores, iou_th, max_det):
    if boxes.shape[0] == 0: return np.empty((0,), dtype=np.int64)
    x1,y1,x2,y2 = [boxes[:,i] for i in range(4)]
    areas = (x2-x1)*(y2-y1)
    order = scores.argsort()[::-1]
    keep = []
    while order.size>0 and len(keep)<max_det:
        i = order[0]; keep.append(i)
        if order.size==1: break
        xx1 = np.maximum(x1[i], x1[order[1:]])
        yy1 = np.maximum(y1[i], y1[order[1:]])
        xx2 = np.minimum(x2[i], x2[order[1:]])
        yy2 = np.minimum(y2[i], y2[order[1:]])
        w = np.maximum(0.0, xx2-xx1); h = np.maximum(0.0, yy2-yy1)
        inter = w*h
        ovr = inter/(areas[i] + areas[order[1:]] - inter + 1e-9)
        inds = np.where(ovr <= iou_th)[0]
        order = order[inds+1]
    return np.array(keep, dtype=np.int64)
def _assemble_heads(outputs):
    boxes_scales, scores_scales, coeff_scales, proto = [], [], [], None
    for _, arr in outputs.items():
        for c_try in (64,32,1):
            try:
                nhwc = as_nhwc(arr, c_try)
            except Exception:
                continue
            n,h,w,c = nhwc.shape
            if c==64 and h in (20,40,80): boxes_scales.append(nhwc.astype(np.float32,copy=False)); break
            if c==1  and h in (20,40,80): scores_scales.append(nhwc.astype(np.float32,copy=False)); break
            if c==32 and h in (20,40,80): coeff_scales.append(nhwc.astype(np.float32,copy=False)); break
            if c==32 and h==160 and w==160: proto = nhwc[0]; break
    if len(boxes_scales)==3 and len(scores_scales)==3 and len(coeff_scales)==3 and proto is not None:
        boxes_scales.sort(key=lambda a:a.shape[1])
        scores_scales.sort(key=lambda a:a.shape[1])
        coeff_scales.sort(key=lambda a:a.shape[1])
        return boxes_scales, scores_scales, coeff_scales, proto
    raise RuntimeError("Failed to assemble heads")
def decode_distribution_boxes(raw_boxes_scales, input_shape, reg_max, strides):
    ih, iw = input_shape
    all_xywh = []
    for t, stride in zip(raw_boxes_scales, strides):
        n,h,w,c = t.shape
        t = t.reshape(n, h*w, 4, reg_max+1)
        prob = softmax(t, axis=-1)
        bins = np.arange(reg_max+1, dtype=np.float32)
        dist = (prob * bins).sum(axis=-1) * stride
        gy = (np.arange(h)+0.5)*stride; gx = (np.arange(w)+0.5)*stride
        gx,gy = np.meshgrid(gx,gy)
        centers = np.stack([gx.ravel(), gy.ravel(), gx.ravel(), gy.ravel()], axis=1)[None,:,:]
        dist = np.concatenate([-dist[:,:,:2], dist[:,:,2:]], axis=-1)
        xyxy = centers + dist
        cx = (xyxy[:,:,0]+xyxy[:,:,2])*0.5
        cy = (xyxy[:,:,1]+xyxy[:,:,3])*0.5
        ww = xyxy[:,:,2]-xyxy[:,:,0]
        hh = xyxy[:,:,3]-xyxy[:,:,1]
        xywh = np.stack([cx,cy,ww,hh], axis=-1)
        all_xywh.append(xywh)
    return np.concatenate(all_xywh, axis=1)
def process_masks(proto, coeffs, boxes_xyxy, out_shape):
    ph,pw,pc = proto.shape
    ih,iw = out_shape
    proto_flat = proto.reshape(-1, pc).T
    masks = sigmoid(coeffs @ proto_flat).reshape(-1, ph, pw)
    out = np.empty((masks.shape[0], ih, iw), dtype=np.float32)
    for i in range(masks.shape[0]):
        out[i] = cv2.resize(masks[i], (iw, ih), interpolation=cv2.INTER_LINEAR)
    boxes = boxes_xyxy.round().astype(np.int32)
    boxes[:,[0,2]] = np.clip(boxes[:,[0,2]], 0, iw-1)
    boxes[:,[1,3]] = np.clip(boxes[:,[1,3]], 0, ih-1)
    cropped = np.zeros_like(out)
    for i in range(out.shape[0]):
        x1,y1,x2,y2 = boxes[i]
        cropped[i, y1:y2, x1:x2] = out[i, y1:y2, x1:x2]
    return cropped
def postprocess(outputs, input_shape, conf=0.40, iou=0.50, max_det=100, no_nms=False, min_lanes=3, mask_thr=0.50):
    boxes_scales, scores_scales, coeff_scales, proto = _assemble_heads(outputs)
    strides = [ih // a.shape[1] for a in boxes_scales]  # 640/80=8, /40=16, /20=32
    reg_max = boxes_scales[0].shape[-1] // 4 - 1       # 64 -> 15
    decoded_xywh = decode_distribution_boxes(boxes_scales, (ih, iw), reg_max, strides)
    scores = [s.reshape(s.shape[0], -1, 1) for s in scores_scales]
    scores = np.concatenate(scores, axis=1)
    obj = np.ones((scores.shape[0], scores.shape[1], 1), dtype=np.float32)
    preds = np.concatenate([decoded_xywh, obj, scores], axis=-1)  # (N,Nprop,6)
    coeffs = [c.reshape(c.shape[0], -1, 32) for c in coeff_scales]
    coeffs = np.concatenate(coeffs, axis=1)
    preds = np.concatenate([preds, coeffs], axis=-1)             # (N,Nprop,38)
    xywh = preds[0,:,:4]
    confs = preds[0,:,4] * preds[0,:,5]
    keep = confs > conf
    if not np.any(keep):
        return dict(mask_union=np.zeros((ih,iw),dtype=np.uint8), masks=np.zeros((0,ih,iw),dtype=np.uint8))
    xyxy_all = xywh2xyxy(xywh)[keep]
    conf_all = confs[keep]
    coeff_all = preds[0,keep,6:]
    if no_nms:
        order = np.argsort(conf_all)[::-1]
        sel_idx = order[:max_det]
    else:
        nms_idx = nms_cpu(xyxy_all, conf_all, iou, max_det)
        if nms_idx.size < min_lanes:
            needed = min(min_lanes, xyxy_all.shape[0])
            union_idx = list(dict.fromkeys(list(nms_idx) + list(order[:needed])))
            sel_idx = np.array(union_idx[:max_det], dtype=np.int64)
        else:
            sel_idx = nms_idx
    xyxy = xyxy_all[sel_idx]
    coeff_sel = coeff_all[sel_idx]
    masks_f = process_masks(proto.astype(np.float32,copy=False), coeff_sel, xyxy, (ih,iw))
    bin_masks = (masks_f > float(mask_thr)).astype(np.uint8)
    union = (bin_masks>0).any(axis=0).astype(np.uint8)
    return dict(mask_union=union, masks=bin_masks)
def masks_union_to_fullsize(masks_bin, pad, out_shape):
    Build a union mask at the original frame size from per-instance masks.
    This mirrors the logic used by lane_positions_from_masks, so status and
    /lane_mask will always agree.
    if not publish_overlay_flag:      # <-- add this parameter
        return None
    import cv2
    h0, w0 = out_shape
    out = np.zeros((h0, w0), dtype=np.uint8)
    if masks_bin is None or not isinstance(masks_bin, np.ndarray) or masks_bin.ndim != 3 or masks_bin.shape[0] == 0:
        return out  # all zeros
    ih, iw = masks_bin.shape[1], masks_bin.shape[2]
    top, left = pad
    nh = ih - 2 * top
    nw = iw - 2 * left
    y0, y1 = top, top + nh
    x0, x1 = left, left + nw
    # clamp just in case
    y0 = max(0, min(ih, y0)); y1 = max(0, min(ih, y1))
    x0 = max(0, min(iw, x0)); x1 = max(0, min(iw, x1))
    if y1 <= y0 or x1 <= x0:
        # fallback: resize whole mask
        for m in masks_bin:
            tmp = cv2.resize(m.astype(np.uint8), (w0, h0), interpolation=cv2.INTER_NEAREST)
            out |= (tmp & 1)
        return out * 255
    # normal path: de-pad then resize each instance, OR into union
    for m in masks_bin:
        unpadded = m[y0:y1, x0:x1]
        if unpadded.shape[:2] != (h0, w0):
            unpadded = cv2.resize(unpadded, (w0, h0), interpolation=cv2.INTER_NEAREST)
        out |= (unpadded.astype(np.uint8) & 1)
    return out * 255  # 0/255
def lane_positions_from_masks(masks_bin, pad, out_wh, yroi, bottom_frac=0.25, min_pixels=1):
    if masks_bin.ndim != 3 or masks_bin.shape[0]==0: return []
    top,left = pad
    h0,w0 = out_wh
    y0f,y1f = yroi
    y0 = int(round(h0*y0f)); y1 = int(round(h0*y1f))
    y0 = max(0,min(h0,y0));  y1 = max(0,min(h0,y1))
    if y1<=y0: y0,y1 = 0,h0
    frac = max(0.02, min(0.50, float(bottom_frac)))
    lanes=[]
    for m in masks_bin:
        unpadded = m[top: ih-top, left: iw-left]
        if unpadded.shape[:2] != (h0,w0):
            unpadded = cv2.resize(unpadded,(w0,h0),interpolation=cv2.INTER_NEAREST)
        found=False
        for scale in (1.0,1.5,2.0):
            use_frac = min(0.50, frac*scale)
            roi_h = y1-y0
            ys0 = y0 + int(round((1.0-use_frac)*roi_h))
            ys0 = min(ys0, y1-1)
            strip = unpadded[ys0:y1,:]
            if strip.size==0: continue
            colsum = strip.sum(axis=0)
            idx = np.where(colsum >= min_pixels)[0]
            if idx.size:
                w = colsum[idx].astype(np.float32)
                x = float((idx*w).sum()/(w.sum()+1e-6))
                lanes.append({"x_px":x, "x_norm": x/float(w0)})
                found=True; break
        if not found:
            strip = unpadded[y0:y1,:]
            if strip.size:
                if idx.size:
    lanes.sort(key=lambda d:d["x_px"])
    return lanes
class LaneEngine:
    def __init__(self, hef_path, output_type="FLOAT32"):
        self.hailo = HailoInfer(hef_path, batch_size=1, output_type=output_type)
        ih, iw, _ = self.hailo.get_input_shape()
        self.input_h, self.input_w = ih, iw
        self._q = queue.Queue(maxsize=1)
    def infer(self, bgr_img):
        # preprocess
        letter, pad = letterbox_bgr(bgr_img, (self.input_w, self.input_h))
        # run async and wait result
        def cb(*cb_args, **cb_kwargs):
            try:
                if cb_kwargs:
                    completion_info = cb_kwargs.get("completion_info", None)
                    bindings_list = cb_kwargs.get("bindings_list", None)
                else:
                    completion_info, bindings_list = cb_args[0], cb_args[1]
            except Exception:
                return
            if hasattr(completion_info,"exception") and completion_info.exception:
                return
            try:
                b = bindings_list[0]
                names = getattr(b, "_output_names", None)
                outs = {}
                if names:
                    for name in names:
                        arr = b.output(name).get_buffer()
                        if isinstance(arr,np.ndarray) and arr.ndim==3: arr = arr[None,...]
                        outs[name]=arr
                else:
                    arr=b.output().get_buffer()
                    if isinstance(arr,np.ndarray) and arr.ndim==3: arr=arr[None,...]
                    outs["out0"]=arr
                if self._q.full(): self._q.get_nowait()
                self._q.put_nowait(outs)
            except Exception:
                pass
        try:
            # try kw first, then positional
            self.hailo.run([letter], callback=cb)
        except TypeError:
            self.hailo.run([letter], cb)
        t0=time.time()
        outputs=None
        while outputs is None:
            try:
                outputs=self._q.get(timeout=0.5)
            except queue.Empty:
                if time.time()-t0>2.0:
                    # retry once
                    try: self.hailo.run([letter], callback=cb)
                    except TypeError: self.hailo.run([letter], cb)
                    t0=time.time()
        return outputs, pad
    def close(self):
        self.hailo.close()
#!/usr/bin/env python3
import json
import threading
import cv2
import rclpy
from rclpy.node import Node
from rclpy.qos import qos_profile_sensor_data
from sensor_msgs.msg import Image
from std_msgs.msg import String
from .lane_core import (
    LaneEngine,
    postprocess,
    masks_union_to_fullsize,
class LaneSegNode(Node):
    def __init__(self):
        super().__init__('lane_seg_node')
        # Params
        self.net = self.declare_parameter('net', 'lane2.hef').get_parameter_value().string_value
        self.input_topic = self.declare_parameter('input_topic', '/image_raw').get_parameter_value().string_value
        self.mask_topic = self.declare_parameter('mask_topic', '/lane_mask').get_parameter_value().string_value
        self.status_topic = self.declare_parameter('status_topic', '/lane_status').get_parameter_value().string_value
        self.overlay_topic = self.declare_parameter('overlay_topic', '/lane_overlay').get_parameter_value().string_value
        self.publish_overlay = self.declare_parameter('publish_overlay', False).get_parameter_value().bool_value
        self.conf = float(self.declare_parameter('conf', 0.40).get_parameter_value().double_value)
        self.nms_iou = float(self.declare_parameter('nms_iou', 0.90).get_parameter_value().double_value)
        self.no_nms = bool(self.declare_parameter('no_nms', False).get_parameter_value().bool_value)
        self.min_lanes = int(self.declare_parameter('min_lanes', 3).get_parameter_value().integer_value)
        self.mask_thr = float(self.declare_parameter('mask_thr', 0.45).get_parameter_value().double_value)
        yroi_str = self.declare_parameter('yroi', '0.45,1.0').get_parameter_value().string_value
        self.yroi = tuple(map(float, yroi_str.split(',')))
        self.bottom_frac = float(self.declare_parameter('bottom_frac', 0.30).get_parameter_value().double_value)
        self.min_pix = int(self.declare_parameter('min_pix', 1).get_parameter_value().integer_value)
        # Engine
        self.engine = LaneEngine(self.net, output_type="FLOAT32")
        self.get_logger().info(f"Loaded HEF: {self.net} input {self.engine.input_w}x{self.engine.input_h}")
        # ROS I/O
        self.sub = self.create_subscription(Image, self.input_topic, self.cb_image, qos_profile_sensor_data)
        self.pub_mask = self.create_publisher(Image, self.mask_topic, 10)
        self.pub_status = self.create_publisher(String, self.status_topic, 10)
        self.pub_overlay = self.create_publisher(Image, self.overlay_topic, 10) if self.publish_overlay else None
        self.lock = threading.Lock()
        self.frame_id = 0
    def _image_to_bgr(self, msg: Image):
        enc = (msg.encoding or '').lower()
        buf = memoryview(msg.data)
        h, w = msg.height, msg.width
        if enc == 'bgr8':
            return np.frombuffer(buf, np.uint8).reshape(h, w, 3)
        if enc == 'rgb8':
            arr = np.frombuffer(buf, np.uint8).reshape(h, w, 3)
            return arr[:, :, ::-1].copy()
        if enc in ('yuv422_yuy2', 'yuyv', 'yuyv422'):
            yuyv = np.frombuffer(buf, np.uint8).reshape(h, w, 2)
            return cv2.cvtColor(yuyv, cv2.COLOR_YUV2BGR_YUY2)
        if enc == 'mono8':
            arr = np.frombuffer(buf, np.uint8).reshape(h, w)
            return np.stack([arr, arr, arr], axis=-1)
        # Fallback: assume at least 3 channels
        arr = np.frombuffer(buf, np.uint8).reshape(h, w, -1)
        if arr.shape[2] >= 3:
            return arr[:, :, :3]
        return np.repeat(arr.reshape(h, w, 1), 3, axis=2)
    def cb_image(self, msg: Image):
        with self.lock:
            try:
                bgr = self._image_to_bgr(msg)
                outputs, pad = self.engine.infer(bgr)
                pp = postprocess(
                    outputs,
                    (self.engine.input_h, self.engine.input_w),
                    conf=self.conf, iou=self.nms_iou, max_det=100,
                    no_nms=self.no_nms, min_lanes=self.min_lanes, mask_thr=self.mask_thr
                # Build union mask at the ORIGINAL msg size (0/255)
                valid_mask = masks_union_to_fullsize(pp["masks"], pad, (msg.height, msg.width)) if self.publish_overlay else None
                # Publish mono8 mask
                mask_msg = Image()
                mask_msg.header = msg.header
                mask_msg.height = msg.height
                mask_msg.width = msg.width
                mask_msg.encoding = 'mono8'
                mask_msg.is_bigendian = 0
                mask_msg.step = msg.width
                mask_msg.data = valid_mask.tobytes()
                self.pub_mask.publish(mask_msg)
                # Status
                lanes = lane_positions_from_masks(
                    pp['masks'], pad, (msg.height, msg.width),
                    self.yroi, bottom_frac=self.bottom_frac, min_pixels=self.min_pix
                s = String()
                s.data = json.dumps({
                    "count": int(len(lanes)),
                    "lanes_px": [float(d["x_px"]) for d in lanes],
                    "lanes_norm": [float(d["x_norm"]) for d in lanes]
                }, separators=(',', ':'))
                self.pub_status.publish(s)
                # Optional overlay
                if self.publish_overlay and self.pub_overlay:
                    ov = bgr.copy()
                    ov[valid_mask > 0] = (255, 128, 0)
                    overlay_msg = Image()
                    overlay_msg.header = msg.header
                    overlay_msg.height = msg.height
                    overlay_msg.width = msg.width
                    overlay_msg.encoding = 'bgr8'
                    overlay_msg.is_bigendian = 0
                    overlay_msg.step = msg.width * 3
                    overlay_msg.data = ov.tobytes()
                    self.pub_overlay.publish(overlay_msg)
                # Optional periodic debug
                self.frame_id += 1
                if self.frame_id % 30 == 0:
                    nnz = int((valid_mask > 0).sum())
                    self.get_logger().info(f"mask nnz: {nnz}")
            except Exception as e:
                # Do not crash the process on a single bad frame
                self.get_logger().error(f"cb_image failed: {type(e).__name__}: {e}")
def main():
    rclpy.init()
    node = LaneSegNode()
    try:
        rclpy.spin(node)
    except KeyboardInterrupt:
        pass
    finally:
        try:
            node.engine.close()
        except Exception:
            pass
        node.destroy_node()
        if rclpy.ok():
            rclpy.shutdown()
if __name__ == "__main__":
    main()
Because we are a team and three people have their own detection model developed, we are using roboflow to hand label things, and we couldnt find a way to combine object detection yolov8 model with lane segmentation yolov8_seg model.
I’m sorry but I think codes are not really organized to read…
But I think segmentation overlay may be the bottleneck. Try to profile each module(preprocess, inference, postprocess) with time and check the results.
If segmentation overlay is the problem, try to optimize it with numba and LUT. (Since it is “embarassingly parallel”)
Hey @Jeongmo_Kim,
Are you doing the NMS for yolov8s on the host with Python? If so, that’s quite inefficient, we’d recommend using hailort_postprocess instead
For YOLOv8s yes but he is also using YOLOv8-seg. From what I know NMS postprocess for YOLOv8-seg is not supported on Hailo chip.
Yes since i built this from the HailoRT examples i am running nms on host python i just realized. What would be the quickest and easiest way to put nms into my yolov8seg hef file so hailo can be fully utilized?
My question was about object detection. For YOLOv8s-Seg, as @Mingyu_Kim mentioned, we still don’t provide a hailort_postprocess (it’s in progress).
I’d follow the earlier suggestion, identify the bottleneck and optimize where needed.
Hi @Jeongmo_Kim
C++ postprocessing for yolov8 segmentation models is available in DeGirum PySDK.
Okay I will take a look thank you!
For YOLOv8s-Seg,When will the hailort_postprocess be available? We are in great need of this function. Thank you.
