I am trying to run a model on a Raspberry Pi 5 with the Hailo-8L chip. I have quantized and compiled a model successfully. I am getting correct output on my desktop when I use ClinetRunner from the Hailo SDK. However, on the Raspberry Pi, I am getting completely different output. Below is the program that I am using for testing inference on the Raspberry Pi 5. It is a modified version of vstreams_example.cpp in the hailort GitHub repo. Why am I getting a different output.? Am I doing something wrong here?
#include <hailo/hailort.hpp>
#include <iostream>
#include <thread>
#include <opencv2/core.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/imgproc.hpp>
#define MEAN_R 0.485
#define MEAN_G 0.456
#define MEAN_B 0.406
#define SD_R 0.229
#define SD_G 0.224
#define SD_B 0.225
#define HEF_FILE ("new_model.hef")
constexpr size_t FRAMES_COUNT = 1;
constexpr size_t MAX_LAYER_EDGES = 16;
using namespace hailort;
using namespace std;
using namespace cv;
float *preprocess(cv::Mat const&mat) {
assert(mat.channels() == 3);
int w = mat.cols;
int h = mat.rows;
int c = mat.channels();
float mu, sigma;
float *buffer = new float[w * h * c];
for(int y = 0; y < h; y++) {
for(int x = 0; x < w; x++) {
float b = (float)*(mat.ptr(y) + x * c + 0);
float g = (float)*(mat.ptr(y) + x * c + 1);
float r = (float)*(mat.ptr(y) + x * c + 2);
b /= 255.0;
g /= 255.0;
r /= 255.0;
b = (b - MEAN_B) / SD_B;
g = (g - MEAN_G) / SD_G;
r = (r - MEAN_R) / SD_R;
buffer[y * w * c + x * c + 0] = r;
buffer[y * w * c + x * c + 1] = g;
buffer[y * w * c + x * c + 2] = b;
return buffer;
Expected<std::shared_ptr<ConfiguredNetworkGroup>> configure_network_group(VDevice &vdevice)
auto hef = Hef::create(HEF_FILE);
if (!hef) {
return make_unexpected(hef.status());
auto configure_params = vdevice.create_configure_params(hef.value());
if (!configure_params) {
return make_unexpected(configure_params.status());
auto network_groups = vdevice.configure(hef.value(), configure_params.value());
if (!network_groups) {
return make_unexpected(network_groups.status());
if (1 != network_groups->size()) {
std::cerr << "Invalid amount of network groups" << std::endl;
return make_unexpected(HAILO_INTERNAL_FAILURE);
return std::move(network_groups->at(0));
void write_all(InputVStream &input, hailo_status &status)
Mat image = imread("BL1575_6.8-FoV-34-crop-0-class-5.png");
if (image.empty()) {
cout << "Could not read image: " << endl;
return ;
float *img_data = preprocess(image);
for (size_t i = 0; i < FRAMES_COUNT; i++) {
status = input.write(MemoryView(img_data, input.get_frame_size()));
if (HAILO_SUCCESS != status) {
return;
// Flushing is not mandatory here
status = input.flush();
std::cerr << "Failed flushing input vstream" << std::endl;
return;
status = HAILO_SUCCESS;
return;
void read_all(OutputVStream &output, hailo_status &status)
std::vector<uint8_t> data(output.get_frame_size());
status = output.read(MemoryView(data.data(), data.size()));
return;
float *out_data = (float*) data.data();
for (int i = 0; i < data.size() / sizeof(float); i++)
cout << out_data[i] << " ";
cout << endl;
return;
hailo_status infer(std::vector<InputVStream> &input_streams, std::vector<OutputVStream> &output_streams)
hailo_status status = HAILO_SUCCESS; // Success oriented
hailo_status input_status[MAX_LAYER_EDGES] = {HAILO_UNINITIALIZED};
hailo_status output_status[MAX_LAYER_EDGES] = {HAILO_UNINITIALIZED};
std::unique_ptr<std::thread> input_threads[MAX_LAYER_EDGES];
std::unique_ptr<std::thread> output_threads[MAX_LAYER_EDGES];
size_t input_thread_index = 0;
size_t output_thread_index = 0;
// Create read threads
for (output_thread_index = 0 ; output_thread_index < output_streams.size(); output_thread_index++) {
output_threads[output_thread_index] = std::make_unique<std::thread>(read_all,
std::ref(output_streams[output_thread_index]), std::ref(output_status[output_thread_index]));
// Create write threads
for (input_thread_index = 0 ; input_thread_index < input_streams.size(); input_thread_index++) {
input_threads[input_thread_index] = std::make_unique<std::thread>(write_all,
std::ref(input_streams[input_thread_index]), std::ref(input_status[input_thread_index]));
// Join write threads
for (size_t i = 0; i < input_thread_index; i++) {
input_threads[i]->join();
if (HAILO_SUCCESS != input_status[i]) {
status = input_status[i];
// Join read threads
for (size_t i = 0; i < output_thread_index; i++) {
output_threads[i]->join();
if (HAILO_SUCCESS != output_status[i]) {
status = output_status[i];
if (HAILO_SUCCESS == status) {
std::cout << "Inference finished successfully" << std::endl;
return status;
int main()
auto vdevice = VDevice::create();
if (!vdevice) {
std::cerr << "Failed create vdevice, status = " << vdevice.status() << std::endl;
return vdevice.status();
auto network_group = configure_network_group(*vdevice.value());
if (!network_group) {
std::cerr << "Failed to configure network group " << HEF_FILE << std::endl;
return network_group.status();
// Set input format type to auto - libhailort will not scale the data before writing to the HW
auto input_vstream_params = network_group.value()->make_input_vstream_params({}, HAILO_FORMAT_TYPE_FLOAT32, HAILO_DEFAULT_VSTREAM_TIMEOUT_MS,
HAILO_DEFAULT_VSTREAM_QUEUE_SIZE);
if (!input_vstream_params) {
std::cerr << "Failed creating input vstreams params " << input_vstream_params.status() << std::endl;
return input_vstream_params.status();
/* The input format order in the example HEF is NHWC in the user-side (may be seen using 'hailortcli parse-hef <HEF_PATH>).
Here we override the user-side format order to be NCHW */
auto input_vstreams = VStreamsBuilder::create_input_vstreams(*network_group.value(), *input_vstream_params);
if (!input_vstreams) {
std::cerr << "Failed creating input vstreams " << input_vstreams.status() << std::endl;
return input_vstreams.status();
// Set output format type to float32 - libhailort will de-quantize the data after reading from the HW
// Note: this process might affect the overall performance
auto output_vstream_params = network_group.value()->make_output_vstream_params({}, HAILO_FORMAT_TYPE_FLOAT32, HAILO_DEFAULT_VSTREAM_TIMEOUT_MS,
if (!output_vstream_params) {
std::cerr << "Failed creating output vstreams params " << output_vstream_params.status() << std::endl;
return output_vstream_params.status();
auto output_vstreams = VStreamsBuilder::create_output_vstreams(*network_group.value(), *output_vstream_params);
if (!output_vstreams) {
std::cerr << "Failed creating output vstreams " << output_vstreams.status() << std::endl;
return output_vstreams.status();
if (input_vstreams->size() > MAX_LAYER_EDGES || output_vstreams->size() > MAX_LAYER_EDGES) {
std::cerr << "Trying to infer network with too many input/output virtual streams, Maximum amount is " <<
MAX_LAYER_EDGES << " (either change HEF or change the definition of MAX_LAYER_EDGES)"<< std::endl;
return HAILO_INVALID_OPERATION;
auto status = infer(*input_vstreams, *output_vstreams);
std::cerr << "Inference failed " << status << std::endl;
return status;
return HAILO_SUCCESS;
