Hi, I now have a Hailo-8 card as PCI Express from Delock in my Proxmox Host.
How can I download the Hailo Drivers aka .deb file?
Via Github I only find releases with Source Code in a zip file.
But I need the .deb to built the driver on my Proxmox Host. The VM way for the Delock didn’t work due to FTR. So it seems I need to go the way of LXC for Frigate with my Intel Arc 380 and Delock Hailo-8 card. Server is a Supermicro Server CSE-829 with X10DRU-i+ Motherboard.
Found those files and got Hailo finally to work with my Frigate LXC. But still can’t get the Intel ARC 310 to run on my Proxmox Host. Seems the missing Rezisable BAR in the BIOS Supermicro X10DRU-i+ is the issue. Also I have Above 4G Decode Enabled. I heard about patching Resize Bar into such a Supermicro Board. Did anyone of you do this and can confirm it works afterwards?
