Dear Hailo Support Team,
I am working on a project to build an AI traffic light detection system using a Raspberry Pi 5 paired with a Hailo AI accelerator. I’m encountering a persistent error when trying to compile my YOLOv5 model using the Hailo AI Software Suite in Docker.
Environment:
- Development machine: Windows PC with WSL2 and Docker Desktop
- Hailo AI Software Suite: Docker (x86) version 2025-04
- Model: YOLOv5su in ONNX format
Error Message:
Exception: Encountered error during parsing: Expecting value: line 1 column 1 (char 0)
Steps Already Taken:
- Set up proper project directory structure with models, images, and configuration files
- Fixed all YAML syntax issues in the main configuration file (indentation, duplicate keys)
- Created multiple versions of the YOLOv5 architecture file:
- Windows-created file
- Docker-native file created with heredoc
- Minimal test YAML file
- Attempted to bypass the architecture file requirement by removing the cfg: line
- Verified file permissions and content visibility within Docker
The error persists across all these approaches, suggesting a deeper issue with the environment configuration, version compatibility, or Docker container state.
Relevant Files:
- ONNX model: yolov5su.onnx
- Configuration: yolov5su_hailo_config.yaml
- Architecture: yolov5s.yaml
I would appreciate your assistance in resolving this issue. Please let me know if you need any additional information or if there are specific diagnostics I should run.
Thank you,
