Orange Pi5 and Hailo8
Greetings, colleagues.
I’m trying to friend Orange Pi5 with Hailo8 board, but facing some issues.
My installation process looks like:
sudo apt-get update && sudo apt-get upgrade
sudo apt install -y build-essential curl make cmake dpkg dkms
sudo dpkg --install /home/orangepi/Downloads/rockchip/hailort-pcie-driver_4.17.0_all.deb
sudo dpkg --install /home/orangepi/Downloads/rockchip/hailort_4.17.0_arm64.deb
python3 -m virtualenv -p python3.10 hailo_platform_venv && . hailo_platform_venv/bin/activate && pip install /home/orangepi/Downloads/rockchip/hailort-4.17.0-cp310-cp310-linux_aarch64.whl
Scan and identify looks fine.
But when i try to benchmark model (from model-explorer) i get some errors:
And also, when i tried to check performance with this, i didn’t get the best performance.
I’ll really appreciate any advice and tips. Thanks.
Hey @Volodimir ,
Nice Work , seems the installlation went good and the run is ok.
As for testing the model before working with it.
We recommend using :
hailortcli run {.hef} OPTIONAL --batch-size
This will give you the performance checks you want.
Regards.
Thanks for quick response @omria,
I did run model as you recommended and got these results, so new question: Is that Recv Rate ok?
Hey @Volodimir ,
This seems ok, maybe a bit low but i cant tell if its wrong or not because this is a custom hef .
You can check this example for reference:
Regards
HI @Volodimir , for orange pi5, i remember that i will have kernel header file in the folder:
orangepi@orangepi:~$ ls /opt/linux-headers*
/opt/linux-headers-legacy-rockchip-rk3588_x.x.x_arm64.deb
May i ask did you install this header file before you install hailort driver and hailort?
secondly, May i ask your help to check the command which pcie generation did you used:
sudo lspci -vvv -d 1e60:2864 | grep LnkSta
mine is gen3(8G) and 4 lane(x4)
if you have gen2 or gen1, it may affect your rev data.
Hi @alex_zh, thanks for reply.
  1. Yes, i did install headers, i couldn’t build pcie driver without them.
  2. If i remember correctly - orange pi 5 has only pcie 2.0 m2 slot, so, yeah, it half throughput.
    But i still don’t understand, why can’t i access power status for example or firmware settings.
    Btw, what is your setup (board)?
I am using
Orangepi5plus_1.0.8_ubuntu_focal_desktop_xfce_linux5.10.160 Could you please let me know which Orange Pi OS or operating system version you are using? It might help in troubleshooting the issue.
