Multi-devices Python API
Good afternoon!
At the moment, I’m testing the code from HailoRT 4.20.0 User Guides using the multi-device startup Python API. The model is used compiled from HailoModelZoo yolov8m.hef
When running this code, there is absolutely no detection result.
Tell me, please, what could be the problem?
from hailo_platform import (
    HEF,
    Device,
    VDevice,
    HailoStreamInterface,
    InferVStreams,
    ConfigureParams,
    InputVStreamParams,
    OutputVStreamParams,
    InputVStreams,
    OutputVStreams,
    FormatType,
    HailoSchedulingAlgorithm
import cv2
from threading import Thread
def infer(network_group, input_vstreams_params, output_vstreams_params, input_data):
    rep_count = 100
        for i in range(rep_count):
            print(f"Итерация {i + 1}/{rep_count}")
            for stream_name, result in infer_results.items():
                if hasattr(result, 'shape'):
                    print(f"Results for {stream_name}: shape = {result.shape}")
                else:
                    print(f"Results for {stream_name}: {result}")
def create_vdevice_and_infer(hef):
    params.multi_process_service = True
    params.device_count = 2
    params.group_id = "SHARED"
    with VDevice(params=params) as target:
        configure_params = ConfigureParams.create_from_hef(hef=hef,
                                                           interface=HailoStreamInterface.PCIe)
        # model_name = hef.get_network_group_names()[0]
        # batch_size = 1
        # configure_params[model_name].batch_size = batch_size
        input_vstreams_params = InputVStreamParams.make(
            network_group,
            format_type=FormatType.FLOAT32,
        output_vstreams_params = OutputVStreamParams.make(
            network_group,
        image_path = 'yolo_on_hailo8/input-images/input_image0.jpeg'
        image = cv2.imread(image_path)
        if image is None:
            raise FileNotFoundError(f"Images {image_path} not found")
        resized_image = cv2.resize(image, (image_width, image_height))
        rgb_image = cv2.cvtColor(resized_image, cv2.COLOR_BGR2RGB)
        input_data = np.expand_dims(rgb_image, axis=0).astype(np.uint8)
        input_data = input_data.astype(np.float32) / 255.0
        input_data = {input_vstream_info.name: input_data}
if __name__ == "__main__":
    hef_path = "yolov8x.hef"
    hef = HEF(hef_path)
    infer_process = Thread(target=create_vdevice_and_infer, args=(hef,))
    infer_process.start()
    infer_process.join()
    print('Done inference')
