I am trying to get some performance metrics of the Hailo 8L chip on how many models can be run simultaneously. I can get metrics using hailortcli monitor but cannot save it to a log file on a continious mode. I need these logs to plot a graphical log to analyse the device capabilities.
Python api supported solution would be good.
Thanks and Regards.
To continuously monitor and log the performance metrics of the Hailo-8L chip, you can use the HailoRT CLI along with a Python script to save the output to a log file. The script utilizes the subprocess module to run the HailoRT CLI commands and capture the output in real time.
Here’s a Python-based solution:
import subprocess
import time
def run_hailort_monitor(device_id, log_file_path):
# Enable monitoring by setting the HAILO_MONITOR environment variable
env_vars = {"HAILO_MONITOR": "1"}
# Command to run the model with the specified device ID
run_command = ["hailortcli", "run", "model.hef", "--device-id", device_id]
# Command to start the monitor
monitor_command = ["hailortcli", "monitor"]
# Open the log file for writing
with open(log_file_path, "w") as log_file:
# Start the monitor process
monitor_process = subprocess.Popen(monitor_command, stdout=subprocess.PIPE, stderr=subprocess.STDOUT, env=env_vars)
# Continuously run the model and capture data
while True:
run_process = subprocess.Popen(run_command, stdout=subprocess.PIPE, stderr=subprocess.STDOUT, env=env_vars)
# Wait for the command to complete and capture the output
output, errors = run_process.communicate()
# Write the output to the log file
log_file.write(output.decode())
log_file.flush()
# Pause before the next run
time.sleep(1) # Adjust sleep time as needed
# Check if the monitor process is still running
if monitor_process.poll() is not None:
break # Exit if the monitor process has stopped
if __name__ == "__main__":
device_id = "0000:nn:00.0" # Replace with your actual device ID
log_file_path = "hailo_performance_log.txt"
Explanation:
Environment Variable: The script sets HAILO_MONITOR=1 to enable performance monitoring.
Running the Model: The model is run using hailortcli run with the specified device ID in a loop to generate continuous data.
Monitoring: The hailortcli monitor command is started in a subprocess to capture performance metrics.
Logging: The output from the model run is continuously written to a log file.
Loop and Sleep: The script loops with a sleep interval to periodically run the model, capturing performance data over time.
Make sure to replace "model.hef" with your actual HEF file and update the device_id to match your setup. Adjust the sleep time according to how frequently you want to capture data.
