Installation of Dataflow Compiler failed on Debian 12.7, pyenv for Python3.10
Hi friends of Hailo,
klaus@penguin:~/Hailo_DataFlow-Compiler$ sudo pip install hailo_dataflow_compiler-3.29.0-py3-none-linux_x86_64.whl
on a Debian 12.7 and
klaus@penguin:~/Hailo_DataFlow-Compiler$ pyenv versions
system
  • 3.10.15 (set by /home/klaus/Hailo_DataFlow-Compiler/.python-version)
    failed with the attached errors.
    Any ideas on what I can do to get Dataflow Compiler to work?
    Klaus
Using cached types_python_dateutil-2.9.0.20241003-py3-none-any.whl (9.7 kB)
Building wheels for collected packages: pygraphviz
Building wheel for pygraphviz (pyproject.toml) … error
× Building wheel for pygraphviz (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [58 lines of output]
running bdist_wheel
running build
running build_py
creating build/lib.linux-x86_64-cpython-310/pygraphviz
copying pygraphviz/init.py → build/lib.linux-x86_64-cpython-310/pygraphviz
copying pygraphviz/agraph.py → build/lib.linux-x86_64-cpython-310/pygraphviz
copying pygraphviz/graphviz.py → build/lib.linux-x86_64-cpython-310/pygraphviz
copying pygraphviz/scraper.py → build/lib.linux-x86_64-cpython-310/pygraphviz
copying pygraphviz/testing.py → build/lib.linux-x86_64-cpython-310/pygraphviz
creating build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/init.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_attribute_defaults.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_clear.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_close.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_drawing.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_edge_attributes.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_graph.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_html.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_layout.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_node_attributes.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_readwrite.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_repr_mimebundle.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_scraper.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_string.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_subgraph.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
copying pygraphviz/tests/test_unicode.py → build/lib.linux-x86_64-cpython-310/pygraphviz/tests
running egg_info
writing pygraphviz.egg-info/PKG-INFO
writing dependency_links to pygraphviz.egg-info/dependency_links.txt
writing top-level names to pygraphviz.egg-info/top_level.txt
reading manifest file ‘pygraphviz.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no files found matching ‘.swg’
warning: no files found matching '
.png’ under directory ‘doc’
warning: no files found matching ‘.html’ under directory ‘doc’
.txt’ under directory ‘doc’
warning: no files found matching ‘.css’ under directory ‘doc’
warning: no previously-included files matching '
~’ found anywhere in distribution
warning: no previously-included files matching ‘*.pyc’ found anywhere in distribution
warning: no previously-included files matching ‘.svn’ found anywhere in distribution
no previously-included directories found matching ‘doc/build’
adding license file ‘LICENSE’
writing manifest file ‘pygraphviz.egg-info/SOURCES.txt’
copying pygraphviz/graphviz.i → build/lib.linux-x86_64-cpython-310/pygraphviz
copying pygraphviz/graphviz_wrap.c → build/lib.linux-x86_64-cpython-310/pygraphviz
running build_ext
building ‘pygraphviz._graphviz’ extension
creating build/temp.linux-x86_64-cpython-310/pygraphviz
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -DSWIG_PYTHON_STRICT_BYTE_CHAR -I/home/klaus/.pyenv/versions/3.10.15/include/python3.10 -c pygraphviz/graphviz_wrap.c -o build/temp.linux-x86_64-cpython-310/pygraphviz/graphviz_wrap.o
pygraphviz/graphviz_wrap.c:9: warning: “SWIG_PYTHON_STRICT_BYTE_CHAR” redefined
9 | #define SWIG_PYTHON_STRICT_BYTE_CHAR
: note: this is the location of the previous definition
pygraphviz/graphviz_wrap.c:3023:10: fatal error: graphviz/cgraph.h: No such file or directory
3023 | #include “graphviz/cgraph.h”
compilation terminated.
error: command ‘/usr/bin/gcc’ failed with exit code 1
[end of output]
Hey @Klaus ,
The error fatal error: graphviz/cgraph.h: No such file or directory means pygraphviz can’t find the required Graphviz development headers. Let’s fix this:
  1. First, install Graphviz development libraries:
sudo apt-get update
sudo apt-get install graphviz graphviz-dev
  1. Then try installing the Hailo Dataflow Compiler again:
  1. If you get compiler errors, make sure gcc is installed:
sudo apt-get install build-essential
  1. Since you’re using pyenv, verify you’re on the correct Python version:
pyenv shell 3.10.15
This should resolve the installation error. Let me know if you need any further help.
Thanks omria! Your first two steps were sufficient to install the Hailo Dataflow compiler. Your help is very much appreciated.
klaus@penguin:~/Hailo_DataFlow-Compiler_2nd$ hailo -h
[info] Current Time: 15:43:44, 10/31/24
[info] CPU: Architecture: , Model: Intel(R) Core™ i7-7Y75 CPU @ 1.30GHz, Number Of Cores: 4, Utilization: 0.0%
[info] Memory: Total: 14GB, Available: 13GB
[info] System info: OS: Linux, Kernel: 6.6.30-02728-g8557330097f3
klaus@penguin:~/Hailo_DataFlow-Compiler_2nd$ pyenv versions
system
  • 3.10.15 (set by /home/klaus/Hailo_DataFlow-Compiler_2nd/.python-version)
