Using HailoRT4.21, Ubuntu24.04, x86_64
Example Code:
from hailo_platform import VDevice, HailoSchedulingAlgorithm, FormatType, HEF
from functools import partial
from threading import Thread, Event
import cv2
import time
import faulthandler
faulthandler.enable()
MODEL_RESOLUTION = (224, 224)
MODEL_PATH = "models/objdet.hef"
def async_inference_target(src_callback, dst_callback, stop_event):
    # Create a VDevice
    try:
        params.group_id = "SHARED"
        params.multi_process_service = False
            infer_model = vdevice.create_infer_model(MODEL_PATH)
            infer_model.set_batch_size(1)
            infer_model.input().set_format_type(FormatType.UINT8)
            infer_model.output().set_format_type(FormatType.FLOAT32)
        print("VDevice and InferModel created successfully.")
    except Exception as e:
        print(f"Error: {e}")
        # Create bindings for it and set buffers
        bindings.input().set_buffer(np.empty(infer_model.input().shape).astype(np.uint8))
        bindings.output().set_buffer(np.empty(infer_model.output().shape).astype(np.uint8))
        print("Configured bindings")
I get the following output in Python
Fatal Python error: Segmentation fault
Current thread 0x000072851e3bd080 (most recent call first):
File “/home/matrix/depth-anything/.venv/lib/python3.9/site-packages/hailo_platform/pyhailort/pyhailort.py”, line 2870 in configure
File “/home/matrix/depth-anything/detect.py”, line 30 in async_inference_target
File “/home/matrix/depth-anything/detect.py”, line 60 in
Segmentation fault
When using GDB to examine the stack trace I see the following:
[Thread 0x7fffc921f6c0 (LWP 7793) exited] [Thread 0x7fffc9a206c0 (LWP 7792) exited] VDevice and InferModel created successfully. Configuring infer model: <class ‘hailo_platform.pyhailort.pyhailort.InferModel’> [Thread 0x7fffca2216c0 (LWP 7791) exited] Thread 1 “python” received signal SIGSEGV, Segmentation fault. 0x0000000000000000 in ?? () (gdb) bt #0 0x0000000000000000 in ?? () #1 0x00007ffff67b96ac in hailort::VDevice::create_configure_params[abi:cxx11](hailort::Hef&) const () from /lib/libhailort.so.4.21.0 #2 0x00007ffff6a1319d in hailort::InferModelBase::configure() () from /lib/libhailort.so.4.21.0 #3 0x00007ffff7373b9c in ?? () from /home/matrix/depth-anything/.venv/lib/python3.9/site-packages/hailo_platform/pyhailort/_pyhailort.cpython-39-x86_64-linux-gnu.so #4 0x00007ffff736ca4e in ?? () from /home/matrix/depth-anything/.venv/lib/python3.9/site-packages/hailo_platform/pyhailort/_pyhailort.cpython-39-x86_64-linux-gnu.so #5 0x00007ffff73cddd3 in ?? () from /home/matrix/depth-anything/.venv/lib/python3.9/site-packages/hailo_platform/pyhailort/_pyhailort.cpython-39-x86_64-linux-gnu.so #6 0x000000000052f35b in ?? () #7 0x0000000000517a4b in _PyObject_MakeTpCall () #8 0x000000000052d196 in ?? () #9 0x000000000051386f in _PyEval_EvalFrameDefault () #10 0x000000000051f993 in ?? () #11 0x000000000050f1cc in _PyEval_EvalFrameDefault () #12 0x000000000051f993 in ?? () #13 0x000000000050ef2b in _PyEval_EvalFrameDefault () #14 0x000000000050db39 in ?? () #15 0x000000000050d79b in _PyEval_EvalCodeWithName () #16 0x00000000005d7fc7 in PyEval_EvalCode () #17 0x000000000060525b in ?? () #18 0x0000000000601794 in ?? () #19 0x00000000005fc0cd in ?? () #20 0x00000000005fb7c7 in PyRun_SimpleFileExFlags () #21 0x00000000005f89ab in Py_RunMain () #22 0x00000000005cc07d in Py_BytesMain () #23 0x00007ffff7c2a1ca in __libc_start_call_main (main=main@entry=0x5cc040, argc=argc@entry=2, argv=argv@entry=0x7fffffffdc48) at ../sysdeps/nptl/libc_start_call_main.h:58 #24 0x00007ffff7c2a28b in __libc_start_main_impl (main=0x5cc040, argc=2, argv=0x7fffffffdc48, init=, fini=, rtld_fini=, stack_end=0x7fffffffdc38) at ../csu/libc-start.c:360 #25 0x00000000005cbf75 in _start ()
Interestingly, this same code works perfectly fine on my Raspberry pi CM4 running bookworm. Any ideas?
