HEF format is not compatible with device. Device arch: HAILO8L, HEF arch: HAILO8
I am getting the following error when I run inference on Hailo-8L model from the following github repo.
HAILO MODELS ZOO
[HailoRT] [error] HEF format is not compatible with device. Device arch: HAILO8L, HEF arch: HAILO8
  File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 2847, in configure
    configured_infer_model_cpp_obj = self._infer_model.configure()
hailo_platform.pyhailort._pyhailort.HailoRTStatusException: 26
  File "/home/suraas/Desktop/face_detection/arcface.py", line 16, in <module>
  File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 2843, in configure
    with ExceptionWrapper():
  File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 111, in __exit__
  File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 156, in _raise_indicative_status_exception
hailo_platform.pyhailort.pyhailort.HailoRTInvalidHEFException: Invalid HEF. See hailort.log for more information
It clearly is under the folder 8L but when I download the model and run the inference it give me the above error. Here is my code used to test the inference.
from hailo_platform import VDevice, HailoSchedulingAlgorithm, HEF
import cv2
timeout_ms = 1000
    # Create an infer model from an HEF:
    infer_model = vdevice.create_infer_model('/home/suraas/Desktop/face_detection/arcface_r50.hef')
    # Configure the infer model and create bindings for it
        # Load and preprocess image
        # Load image
        image = cv2.imread('/home/suraas/Desktop/face_detection/images/sample2.png')
        # Resize image to match model's expected input shape
        resized_image = cv2.resize(image, (112, 112))  # Note: cv2.resize takes (width, height)
        # Convert to appropriate format (usually float32 or uint8 depending on model)
        input_tensor = resized_image.astype(np.uint8)
        # Set the preprocessed image as input
        bindings.input().set_buffer(input_tensor)
        # Get all output tensors
        output_tensors = infer_model.outputs
        # Print output shapes for debugging
        for output in output_tensors:
            print(f"Output '{output.name}' shape: {output.shape}")
        # Create buffers for each output
        output_buffers = {}
            # Create buffer with exact shape and use uint8 dtype
            buffer = np.zeros(output.shape, dtype=np.uint8)
            bindings.output(output.name).set_buffer(buffer)
            output_buffers[output.name] = buffer
        # Run synchronous inference
        configured_infer_model.run([bindings], timeout_ms)
        # Get results from each output buffer
        results = {}
        for output_name, buffer in output_buffers.items():
            results[output_name] = bindings.output(output_name).get_buffer()
        # For async inference
        job = configured_infer_model.run_async([bindings])
        job.wait(timeout_ms)
Hi @hyperwolf,
The Hailo Model Zoo master branch has been updated to version 2.14.0 due to the upcoming Software Suite release (2025-01). Therefore, some models are not available for Hailo-8L yet. Apologies for the inconvenience.
Please get the model from the Model Zoo version 2.13.0, which is compatible with HailoRT 4.19.0.
You can use hailortcli parse-hef command to verify the architecture the HEF
was compiled for. For example, using v2.13 arcface_r50 model:
hailortcli parse-hef arcface_r50.hef
Network group name: arcface_r50, Multi Context - Number of contexts: 6
    Network name: arcface_r50/arcface_r50
        VStream infos:
            Input  arcface_r50/input_layer1 UINT8, NHWC(112x112x3)
            Output arcface_r50/fc1 UINT8, NC(512)
